Home > Td5 > 2006 defender headlight wiring
micke
United Kingdom 2016 Defender 90 Puma 2.2 CSW Keswick Green
Hello,
Does anyone know if there are bullet connections behind the wing liner so that I can use the link wire part AMR2357 to replace my damaged head light wiring.
Many thanks.
Post #254941 31st Jul 2013 1:24pm
I wouldn't have thought so. All the Td5 bits I've played with are one length of wire and moulded plugs at each end, no bullets at all anywhere, they were phased out when the 300Tdi came in.
Post #254954 31st Jul 2013 3:13pm
Les Brock
Nope staight through,
you cab get these tho which help, cut off the plugs and through crump Question
http://www.ebay.co.uk/itm/H4-472-3-Pin-HEA...43ae031f5a
Regards
Les[/url]
Post #254956 31st Jul 2013 3:19pm
micke
Many thanks to you both
Post #255040 31st Jul 2013 7:36pm
