![]() | Home > Td5 > 2006 defender headlight wiring |
micke Member Since: 26 Mar 2013 Location: Kent Posts: 13 ![]() ![]() ![]() |
Hello,
Does anyone know if there are bullet connections behind the wing liner so that I can use the link wire part AMR2357 to replace my damaged head light wiring. Many thanks. |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 174 ![]() ![]() |
Nope staight through,
you cab get these tho which help, cut off the plugs and through crump ![]() http://www.ebay.co.uk/itm/H4-472-3-Pin-HEA...43ae031f5a Regards Les[/url] |
Many thanks to you both
