Home > My Defender > davidwhittaker's black 110 Utility Wagon & ongoing mods
Page 5 of 10 <12345678910>
Cheshire110
Yeah chuffed, thanks!
REUNITED WITH ITS FAMILY!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #269586 26th Sep 2013 2:32pm
Sockpuppet
Good news. Can't help but feel you're being a little harsh on the warranty company. You did by your own admission put diesel full of crap into it, which may or may not have caused the pump to fail but you've got to admit the timing is a little suspect.
Post #269599 26th Sep 2013 3:54pm
Cheshire110
Yeah dead relieved.
Maybe I am, but it's the vague way they say / do everything and the lack of logic they insist on using when solving/remeding the problem
Example: they insist on having tank, lines, filter cleaned or replaced (luckily at GS cost because they agreed with us) even though the car ran badly on a direct feel of fuel from a can into the high pressure pump. They also sent an engineer out who concluded that either the pump or injectors are damaged - not sure which, but said that whichever it was must have failed because of fuel contamination, since there was 'evidence of contamination'.
No idea what 'evidence of contamination' - we asked if they had taken a sample of fuel, they said they had taken 2-3 pints and that it was obviously contaminated? The tank had been drained and all that was in it was a second consecutive tank of brand new supermarket fuel so not sure about that.
They also said that whichever it was - pump or injectors - that had failed, they wouldn't cover it because either of them could have been caused by contamination. Maybe it's just me but I'd expect them to want to see which part had failed and determine why.
The failure could have been unrelated but since I had replaced filters etc as an early precaution they just jump on that bandwagon and deny warranty without further inspection.
As a logical practical person I'd want to know why and for sure what had gone wrong... Cheers, David
Post #269604 26th Sep 2013 4:23pm
a13x
Unfortunately logic doesn't always come in to the equation with warranty. The inspection came to a halt immediately after finding parts had been replaced. I suspect that if the car had been taken with no self diagnosis/ replacement of parts then you would probably had a good assessment and greater chance of a successful claim.
You could relate to a scenario of returning an electrical item that stopped working but before you returned it, you chopped off the plug and fitted a replacement in an attempt to repair. Not many retailers would accept your claim.
Post #269607 26th Sep 2013 4:37pm
Cheshire110
cant wait for this again...
AT tyres for christmas, should help greenlaning too (GG TRs getting pretty worn now with nearly 60k on)
Post #274387 16th Oct 2013 8:29pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Glad its all ok Thumbs Up cant wait for the snow in my new one, should be very different than the 300 tdi
Post #274405 16th Oct 2013 9:31pm
Cheshire110
heated front screen is a dream come true too!
and heated seats, and a heater that works Smile Cheers, David
Post #274406 16th Oct 2013 9:33pm
CarbonEvora
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
David,
Where did you source the steering guard from, it looks quite substantial?
Post #274420 16th Oct 2013 10:26pm
Cheshire110
It came from eBay second hand I'm afraid, and has no branding on.
It's aluminium and pretty thick, held on by 2 separate brackets which were easy to fit.
Cost me £60/70 if I remember correctly
But a quick ebay search revealed this - http://item.mobileweb.ebay.co.uk/viewitem?...0673744042 - which looks a very similar one (could be same manufacturer but I'm not sure) Cheers, David
Post #274422 16th Oct 2013 10:33pm
Cheshire110
Further thought-
That ebay one doesn't have tow rings so can't be the same one, but a google (John craddocks are good) or ebay search will reveal a number of options, I'd reccomend aluminium as they are rust prone obviously. Make sure aluminium brackets and stainless bolts too Cheers, David
Post #274424 16th Oct 2013 10:36pm
CarbonEvora
Thanks David, I get my new one next month, so a bit of time to source some nice bits, as you have done!
Post #274425 16th Oct 2013 10:48pm
Cheshire110
What are you getting? New I guess?
And some advice I kinda learned the hard way - get the best one you can afford first time, whatever it is.
This is my second set of DRLs and the LED fog lights are condensing up so will need replacing sometime, it's cheaper just to get good ones first time round or wait til you can Smile Cheers, David
Post #274427 16th Oct 2013 11:01pm
davidwhittaker wrote:
Further thought-
You sure you have aluminium brackets? Just never heard of one with that before.
Post #274451 17th Oct 2013 7:23am
Cheshire110
Hmm I think so,
They're certainly not mild steel and they don't look like stainless.. But could be another alloy I guess? Or slightly worn/pitted stainless...
Either way, avoid mild steel or powder coated IMO Cheers, David
Post #274479 17th Oct 2013 9:46am
They're typically mild steel and some are galvanised, which could be what you're seeing. Aluminium isn't strong enough (in a sensible thickness) to be used for the brackets.
I'd also be very wary of stainless bolts for this application. Unless you choose some very expensive 12.9 ones, then they're too brittle for structural use. Again, typically they're 8.8 steel, which is perfectly adequate if protected properly. Darren
Post #274493 17th Oct 2013 10:40am
