Home > Puma (Tdci) > Knocking Noise Inside Rear
schuee
About 2 weeks ago started to notice a knocking noise from what it sounds is coming from inside the rear of my 110, I have been in the back and checked everything and it all seems tight, it seems to happen when going over small bumps in the road or when turning sharply at slow speed,it does sound like it is from inside though I know how noise can travel so could be coming from underneath. I have even had the kids listening to try and notice where the noise is coming from, SWMBO says she cannot hear it, but I did expect that from her anyway Laughing
The next step would be for me to climb in the back and put my life into her hands whilst she drives around Rolling with laughter and have a look myself, though if anybody else has had a similar thing, or any advice to check that would be great.
Keith
Post #251822 17th Jul 2013 8:46am
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
You could lok at the upper shock absorber bushes, you'd get the knocking reverberating through the body. A lower one has just gone on our August 2010 110 so sometimes they don't last long!
Post #251827 17th Jul 2013 8:57am
schuee
Thanks JR I will take a look later on Thumbs Up
Post #251828 17th Jul 2013 9:02am
I had a similar thing a little while ago that turned out to be a rear mudflap bracket that had come adrift. I was convinced that the sound was coming inside and had my kids prodding and pushing their seats to try and track in down Rolling Eyes Darren
Post #251837 17th Jul 2013 10:05am
mk1collector
If your rear door hinges are going the door can bang on the retaining strip on the floor/bottom of door catch
Post #251839 17th Jul 2013 10:21am
schuee
I did go through my mind it may be something to do with the back door, like something loose inside, will check mudflap brackets also,
Many Thanks
Post #251841 17th Jul 2013 10:30am
keith
Exactly same symptoms with me . It was rear chassis step and rumbling all the time . A common fault , the bolt isn't loose but step rumbles and shakes . My dealer replaced and no more rumbles ( from the back anyway )
Post #251852 17th Jul 2013 11:41am
spudfan
Ireland
If you have an adjustable tow bar fitted check that. See if there is any play when you hold the towball and check for any slight movement against the slider plate. I put some duct tape between the slider plate and the plate with the towball. This killed my rear clunking noise. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #251936 17th Jul 2013 4:43pm
familymad
Have you let the kids out? They start knocking after a while 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #251938 17th Jul 2013 5:05pm
mk1collector
Post #251941 17th Jul 2013 5:25pm
schuee
Laughing Laughing
Well tonight have had another good look, I bunged up the towbar when I first got it, as I noticed it clanking away, checked bushes on the shock absorbers and door brackets all look ok, I have packed out again with rubber strips the protective cowl which covers the diesel filter in the rear drivers side wheel arch, as this was flapping around again, so will know tomorrow.
Though whilst I was under it tonight I banged under the floor pan and this strangely sounded very similar, could the floor be loose some where?
Anyway thanks for everybody's input, Thumbs Up
Keith
Post #252007 17th Jul 2013 9:10pm
Agauto
Ireland 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Did you ever find out what the noise was. Have same problem myself.
Post #458492 27th Sep 2015 6:48pm
schuee
Morning,
Never did find out what it was mate, eventually the knocking sound went away, just one of those Defender funnies i suppose Smile
Post #459196 30th Sep 2015 8:47am
HardCharger
Unsecured seat belts? They do tend to make a racket when they are not secured in the side holders when not in use.
Or, if the rear passengers are not using their seat belts and lean on that pillar or if they position themselves just right on the seats near the bulkheads, that will cause the seat belt T-clip thingie to bounce against the pillar causing a racket.
Post #459431 1st Oct 2015 2:55am
