Home > Puma (Tdci) > Knocking Noise Inside Rear |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
You could lok at the upper shock absorber bushes, you'd get the knocking reverberating through the body. A lower one has just gone on our August 2010 110 so sometimes they don't last long!
17th Jul 2013 8:57am |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
Thanks JR I will take a look later on |
17th Jul 2013 9:02am |
I had a similar thing a little while ago that turned out to be a rear mudflap bracket that had come adrift. I was convinced that the sound was coming inside and had my kids prodding and pushing their seats to try and track in down Darren
17th Jul 2013 10:05am |
If your rear door hinges are going the door can bang on the retaining strip on the floor/bottom of door catch
17th Jul 2013 10:21am |
I did go through my mind it may be something to do with the back door, like something loose inside, will check mudflap brackets also, Many Thanks |
17th Jul 2013 10:30am |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2214 |
Exactly same symptoms with me . It was rear chassis step and rumbling all the time . A common fault , the bolt isn't loose but step rumbles and shakes . My dealer replaced and no more rumbles ( from the back anyway )
17th Jul 2013 11:41am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4695 |
If you have an adjustable tow bar fitted check that. See if there is any play when you hold the towball and check for any slight movement against the slider plate. I put some duct tape between the slider plate and the plate with the towball. This killed my rear clunking noise. 1982 88" 2.25 diesel
17th Jul 2013 4:43pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Have you let the kids out? They start knocking after a while 1951 80" S1 2.0
17th Jul 2013 5:05pm |
17th Jul 2013 5:25pm |
Well tonight have had another good look, I bunged up the towbar when I first got it, as I noticed it clanking away, checked bushes on the shock absorbers and door brackets all look ok, I have packed out again with rubber strips the protective cowl which covers the diesel filter in the rear drivers side wheel arch, as this was flapping around again, so will know tomorrow. Though whilst I was under it tonight I banged under the floor pan and this strangely sounded very similar, could the floor be loose some where? Anyway thanks for everybody's input, Cheers Keith |
17th Jul 2013 9:10pm |
Agauto Member Since: 27 Sep 2015 Location: Co. Londonderry Posts: 2 |
Did you ever find out what the noise was. Have same problem myself.
27th Sep 2015 6:48pm |
Morning,
Never did find out what it was mate, eventually the knocking sound went away, just one of those Defender funnies i suppose |
30th Sep 2015 8:47am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 740 |
Unsecured seat belts? They do tend to make a racket when they are not secured in the side holders when not in use.
Or, if the rear passengers are not using their seat belts and lean on that pillar or if they position themselves just right on the seats near the bulkheads, that will cause the seat belt T-clip thingie to bounce against the pillar causing a racket. |
1st Oct 2015 2:55am |
