Home > Puma (Tdci) > TDCi bonnet release
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
TDCi bonnet release
Going to dealer this week for a few minor warranty issues and Q068v4. One problem is the bonnet release cable. Impossible to release again today to check oil/washers etc. Handle just pulls as far as it can go (about 150 degrees) but does not release the bonnet catch. Has already been adjusted three times in the last 18 months. Anyone else with this problem or advice I can give to the dealer for a permanent solution?
Post #19559 6th Dec 2009 7:14pm
fekete
Tell them to put a new one on instead off adjusting it Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #19560 6th Dec 2009 7:27pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I used to have a problem opening the bonnet. I'd pull the handle all the way but it wouldn't open unless I then kneeled on the front edge of the bonnet, and then bounced about until it finally released. I thought it was the cable but it was due to go in for a service at the time, and my local independent dealer said they had seen a number of them with sticky latches. Sure enough when it came back it was nicely greased and it's worked perfectly ever since. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #19561 6th Dec 2009 7:45pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
well i had mine under-ajusted a couple of times, it always need'd pulling to its full extent to "pop" the bonnet, this would in time slip and not be able to pop, then it was over ajusted and only need'd only a slight pull to popthis then broke a connector in the cable, yes thats right the cable has a join in the middle that can fail Question fourth or fifth try and they got it right, it now works fine.
Post #19568 6th Dec 2009 11:28pm
CapeLandy
South Africa
I found that the two adjustable rubber stoppers on the inside of the bonnet were sticking out too far and causing undue tension on the catch in the center. Turn them in a few turns if you get your bonnet open eventually and keep trying different lengths until it opens easy. Don't turn them in too far otherwise the bonnet will rub on the checker plate on the side fenders.
Good luck Puma 110 - gone
Series III 1973 - going strong
Post #19570 7th Dec 2009 8:12am
Cannonball
Thanks for your comments. Going in on Wednesday, will pass them on to the dealer. In the meantime they have ordered a replacement cable just in case.
Post #19578 7th Dec 2009 9:44am
