![]() | Home > Puma (Tdci) > TDCi bonnet release |
Tell them to put a new one on instead off adjusting it
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
I used to have a problem opening the bonnet. I'd pull the handle all the way but it wouldn't open unless I then kneeled on the front edge of the bonnet, and then bounced about until it finally released. I thought it was the cable but it was due to go in for a service at the time, and my local independent dealer said they had seen a number of them with sticky latches. Sure enough when it came back it was nicely greased and it's worked perfectly ever since. Peter
2008 SWB Truck Cab 1952 80" Soft top |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
well i had mine under-ajusted a couple of times, it always need'd pulling to its full extent to "pop" the bonnet, this would in time slip and not be able to pop, then it was over ajusted and only need'd only a slight pull to popthis then broke a connector in the cable, yes thats right the cable has a join in the middle that can fail
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I found that the two adjustable rubber stoppers on the inside of the bonnet were sticking out too far and causing undue tension on the catch in the center. Turn them in a few turns if you get your bonnet open eventually and keep trying different lengths until it opens easy. Don't turn them in too far otherwise the bonnet will rub on the checker plate on the side fenders.
Good luck Puma 110 - gone Series III 1973 - going strong |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Thanks for your comments. Going in on Wednesday, will pass them on to the dealer. In the meantime they have ordered a replacement cable just in case.
