![]() | Home > Puma (Tdci) > transferbox bolt torque |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
Hello,
Could you take a picture, are you sure that it doesn't come from the seal of the rear output shaft. ![]() |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 124 ![]() ![]() ![]() |
Hi Apynala
just seem to get droplet of oil on lowest bolt have cleaned down but carnt see any oil running down from above can take picture tomorrow pitch black at the moment , cheers bunny |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
Hi the drain bolt torque on transfer box is 50nm (filler bolt torque is 35nm)
cheers kmac
the bolt torque i needed was the bolts on the lower case gasket for when i renew it saturday, didnt want to over tighten |
