Home > Puma (Tdci) > transferbox bolt torque
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
Hi all
have oil leak on bottom gasket on my puma 09 defender transfer box, does anybody know the tourqe settings for the bolts and any other tips would be greatly appreciated .
many thanks bunny
Post #246678 25th Jun 2013 6:32pm
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Hello,
Could you take a picture, are you sure that it doesn't come from the seal of the rear output shaft.
Wink
Post #246751 25th Jun 2013 10:02pm
bunnyman
Hi Apynala
just seem to get droplet of oil on lowest bolt have cleaned down but carnt see any oil running down from above can take picture tomorrow pitch black at the moment , cheers bunny
Post #246762 25th Jun 2013 10:15pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hi the drain bolt torque on transfer box is 50nm (filler bolt torque is 35nm)
Post #246809 25th Jun 2013 11:04pm
bunnyman
cheers kmac
the bolt torque i needed was the bolts on the lower case gasket for when i renew it saturday, didnt want to over tighten
Post #246815 25th Jun 2013 11:11pm
