![]() | Home > Maintenance & Modifications > P&P Roll cages |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
I was considering fitting a P&P external roll cage to my utility when I get it and the main reason for it is-
I caravan so rooftop tent will be unlikely and we have the 110 TD5 with frontrunner rack if it was neccessary. The only thing I will be transporting regularly will be a open canoe which would surely secure to the roll cage, I think it will add to the looks of the vehicle and the cost is similar to a hannibal rack. Are there any major reasons why not to go for the roll cage ![]() |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Looks
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6162 ![]() ![]() ![]() |
P&P full external (plus internal hoop) on my 110. love it.
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 588 ![]() ![]() ![]() |
looking good.
I am considering p+p too, I want a roof rack but they are expensive. Thinking of going this route and incorporating something to use as a rack. Did you fit this yourself? Steve |
Looks great, nice to see it on a black vehicle, because it looks stunning on markalpha's white ute
![]() The snorkle though, it looks like you made a big hole in your wing top for it? and where does the arial fit now ![]() |
They may be a bit pricey (although nothing compared to safety devices) but they don't rust within a month due to bad coatings. yeah, fitted it myself. pretty easy really, especially as i was building the 110 at the time anyway.
it's actually epsom metallic green, just looks dark in that light. yes. i cut a hole through the top of the wing, just so it wasn't exposed on the side where it could get damaged. i fitted my aerial on the back of the cage (next to the coily CB antenna) although it would normally go where the snorkel is. |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Steve talk to P and P about mesh on top of the roll cage, works a treat! No need for a rack!
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
very nice jim, me want one !
Thats what I'm thinking about ![]() Hey Jim, does it need welding, I'm good at cutting and bolting but no welding. Steve |
The full cage looks very cool
![]() ![]() ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Would waxoil applied before the build stop this happening or are rubber bungs maybe the answer? 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
Both sound ok, it is not a huge problem but you do get water marks on the roof section above the front doors and as mine is white it really shows up.
MUF Member Since: 31 Jul 2009 Location: Super Burnley Posts: 68 ![]() ![]() ![]() |
Lovin' those GALV side runners :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
glr Member Since: 13 Sep 2008 Location: Brickendon Posts: 19 ![]() ![]() |
Jim, Did you go with the internal roll bar? We just had Dan fit a cage to a vehicle we just finished for an American Client, I will try and post pics tomorrow. We normally get Dan Evans To fit our cages and we can also supply their cages. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
