![]() | Home > Td5 > Coughing |
That sounds like the MAF on its' way out. Had a similar thing on a DII where it would miss or stutter every now and then, and a new MAF cured it. Darren
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
Thanks, can you test the MAF to check this ? Sweatysock ------------- 110 CSW TDCI (Puma) 2007 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20603 ![]() ![]() |
Give it a clean first and see how it goes.
okay and where do I find this beastie (MAF) please Sweatysock ------------- 110 CSW TDCI (Puma) 2007 |
I'm not sure myself as I have a Puma but someone will be able to tell you soon no doubt. Or Google it?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5800 ![]() ![]() |
The MAF is just after the air filter box, it has two clips holding it on to the air filter box and a jubilee clip the other side, and one connector on the side at the top, easy to find/deal with.
It does sound like a MAF. If it is and it needs replacing, get one from alive, they are cheaper than dealers and are uprated units ![]() Andy |
thanks Andy, helpful info Sweatysock ------------- 110 CSW TDCI (Puma) 2007 |
