Home > Puma (Tdci) > Hand brake light stays on intermittently on hill descent |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
I believe the dashboard light comes on for 2 reasons:-
1. Handbrake ON. 2. Hydraulic brake fluid level LOW. Have you checked the fluid level. With footbrakes on and steep descent the level may be such that it is just enough to trigger the fluid level sensor. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
17th Jun 2013 4:28am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 753 |
As Welsh Gas says, low fluid level....
17th Jun 2013 4:44am |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 |
will check that and revert.
17th Jun 2013 7:52am |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
I would check the brake pads first...might be worn, and causes the brake fluid level to drop...
If the brake pads are not worn then it could be brake fluid level... Or it could be a handbrake switch failure Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
17th Jun 2013 5:28pm |
stewalex1984 Member Since: 06 Mar 2013 Location: Glasgow Posts: 9 |
Hi, wondered if you got a solution to this?
30th Jan 2014 6:37pm |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 |
I had this issue and mentioned it in a previous thread on a new 110 DCPU XS.
The solenoid switch in the handbrake turned out to be faulty, so every time I went down a hill the light came on and flickered like a . The stealers replaced the solenoid switch and the issue went away. You may be fobbed off by being told the switch is not correctly aligned. They are so cheap and require abit of faffing with the hand brake gator off, they might aswell just replace it rather the potential of 2 visits |
30th Jan 2014 9:52pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
New pads will be needed
30th Jan 2014 9:55pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
Same here. It is a LR. Puma 110" SW
30th Jan 2014 10:08pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1921 |
Had the same issue with mine and was told by stealer the abs plug/connecter was loose
worth a look 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
30th Jan 2014 10:13pm |
