![]() | Home > My Defender > My Keswick Green XS USW |
Very nice! I really like it!
![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
I think that has turned out rather well. I never did like those grey/silver fronts. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6168 ![]() ![]() ![]() |
That does look really nice.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Like it, I'll have to keep an eye out for you as you're local
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
I'm starting to get really jealous! www.td5.org
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
I really like this defender, very classic.
I'm half considering getting some white wolfs and MTRs for my UW when it turns up as some winter rims. |
Very much looking forward to the roof rack install, as I will be getting one next year for the rooftent. 2011 110 USW
The only problem I can see with that is they look so good in the sun you'll want to leave them on all year round ![]() |
Steve R Member Since: 13 Jun 2012 Location: Leamington Spa & Walton-on-the-Naze Posts: 166 ![]() ![]() |
Well here's the rack install (and RAI)... Really pleased with the Brownchurch HD kit - not as heavy as it looks either (36kg including ladder and waist struts according to the courier label). ![]() Click image to enlarge Proper pics to follow, just thought I'd upload one from my phone for starters. I have a Maggiolina Safari roof tent being fitted on Saturday, then I can crack on with fitting the Foxwing. Getting there slowly! ![]() |
That looks superb, thats the same snorkel as I want to fit to mine, and the roofrack looks great too! 2011 110 USW
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3483 ![]() ![]() ![]() |
What RAI is it?
Does it require much drilling? 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
It's the one from Blanchard's on eBay with military-spec powder coating (much better quality!) here. http://www.ebay.co.uk/itm/Land-Rover-Defen...1e6f81a285 It requires one extra hole drilling in the wing around the air intake hole and drilling of the windscreen frame for a couple of brackets (unless you mount it on the roof rack waist strut like I have). Hope that helps! Steve. |
I think that's a much better solution than having to drill the windscreen frame. Do you have any close up photos of where the waist strut attaches to the bulkhead? |
I will take some detailed pics later - basically you remove the screen hinge and drill through where the centre bolt hole is in the hinge. The new bolt passes from the strut through the hinge and through the bullhead panel. I figured it was fairly cheap and easy to replace the hinges if I ever wanted to get rid of the rack. The rear struts require a hole to be drilled through the capping, but this could be filled with a rivet if the rack was removed. I will post some pics later... |
