![]() | Home > My Defender > What Did You Do In Your Defender Today |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11240 ![]() ![]() ![]() |
I watched mine being driven away by its' new owner tonight
![]() Cheered myself up by fitting a new dog guard to my Discovery ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Got some very scary quotes for repairs
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
What needs doing? On a tdi?
Yes she is a 1991 110 CSW
![]() Top of bulkhead both sides getting very holey - recommended change bulkhead as patch would never be as good as original. Clutch still needs doing as does rear oil seal leak which is getting worse. Rear diff needs its nose seal doing as its loosing lots of oil (and I'll be dammed if I'm responsible for the death of a motor cyclist) And I've got a horrible feeling my injectors are getting very "clickey" which could ether mean injectors warn or fuel pump needs reconditioning which after 149500 is very likely... |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Drove along the M25 / M4 and into Chiswick
Only half way there with "operation total soundproofing" but so far it's sooooooo much better ![]() |
Fixed my uphill power loss on my Td5
there are some good guides about for doing those yourself, if you are so minded. The bulkhead is a big job if it does need changing, but clutch and diff seal aren't too major - the seal is pretty straightforward. Injectors - I've bought reconned sets from united diesel for around Ł250-300 and they're extremely simple to install. |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
Got rid of my annoying rattle.
It's amazing what you find behind the rear speakers of a 110. Good old land rover left some bits for me to find, there such fun ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19802 ![]() ![]() |
Got a good photo opportunity.
![]() ![]() Click image to enlarge |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6769 ![]() ![]() ![]() |
It went straight through with just two advisories for "slightly corroded brake pipes" so a quick clean up and a covering of grease and she's all legal for another year ![]() ![]() |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2731 ![]() ![]() |
Drove a 400 mile round trip today to get a remap and a few little bits from Chris at CSK.
Wasn't sure what to expect but Chris was a pleasure to deal with, had a good chat and look around the place and most importantly the car drives beautifully now, pulls like a train in the higher gears and no juddering in the lower ones. Throttle response is sharper and the car 'kangaroos' much less. Well pleased! Strongly recommend it, how the 2.4 should have lest the factory. And a very reasonable price too compared to the competition. Thanks a bunch, Chris! ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Diabolo - I'll make a post
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
so what was problem? My 109 thread my youtube channel |
removed front +2" HD springs and fitted standard height with isolators back end in air now!
![]() Click image to enlarge My 109 thread my youtube channel |
