Page 621 of 1382 <123 ... 620621622 ... 138013811382>
excossack
^ +1 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #297965 11th Jan 2014 10:22pm
JWL
Back to the thread. So today, having some spare time I looked in to why one of my spotlights has been working a little independently, turned out that the earth tab on the bulb holder had snapped off. I tried to solder a wire with a suitable connector onto the bulb holder but as it was made of die-cast muck it wouldn't stick so a bodge job was required. Just stripped off about an inch of insulation and threaded it around the wire retainer that holds the bulb in, bit of solder to keep the wires all together, sorted. The other spotlight on the A bar dismantled to empty the last of the Salisbury Plain puddle water, well when the water was lapping on the bulkhead there has to be some consequences. The air filter had a wet spot in it, I only have a raised air intake and never did intend to use it as a snorkel.
Still had some time left so I decided to put my newer winch cable on, my old one, whilst not ever been overworked is over 6 years old and is not looking very pretty, becoming very rusty. I pulled the old one off, disconnected the fixing to the drum, got the other one and fixed the end in place. Then the fun bit, dragged it out up the street in a straight a line as possible inbetween the parked cars. Look round to see if any neighbours about, before I trip them up or drive their motor on the cable. Right now winch in, all going well keeping some tension on, I'll respool it when I get the chance and space later, all of a sudden there was a snag winching in, as it came down the street the hook had snagged on a gully cover and flipped it open, the trouble with using wireless winch controllers is the delay in response of the winch, for more control I use the corded handset but the wireless one is less bulky. All got sorted, drain covers returned to position, no granny's dragged kicking and creaking down the street so a succesful outcome, much nicer when the sun is out as well.
Post #297974 11th Jan 2014 10:53pm
Trundled down to Yeovil to drop off the black hannibal, took the back roads due to the flooding.
Post #298020 12th Jan 2014 8:54am
ericvv
Still sunny and mild here, but next week will turn colder so the early morning salting brigades will come back in full force. Rolling Eyes
So today cleaned it (=car wash Cool ), including chassis high pressure spray, towel dried it, cleaned engine compartment (underside of the hood remains bit dirty due to dust gathering onto the Dinitrol), checked engine oil, treated outside plastics and engine compartment plastics (A-bar, door mirrors, door handles, etc.), tire shined it, then brought it to town and put it in our office parking. Where it will remain til next thursday when it will go to the dealer for the hopefully final solution for the recently new installed, but blocked fuel tank breather pipe. Dealer will replace it by a new one which they ordered.
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #298051 12th Jan 2014 11:54am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Small update for me
Yesterday:
I fixed the drivers electric window which decieded to stop working on friday luckly the window was up, after checking everything (fuse, switch, wiring and the motor) it turned out that the red wire had almost snapped in two and the blue had completely gone. After stripping the crap wire soldering and adding some heatshrink we have working windows again Mr. Green
Assembled my new rhino delta roof bars and got the fitted.
Today drove to ludlow and collected my ladders and a full car load of misc (exhausts, wood, tools), i am very happy with the roof bars i went for 3. They are heavy though but didnt add to the noise inside the cab until the rachet straps started to hum alittle when travelling @60 but less than the transmission and cooper stt tyres. 2004 TD5 Defender 90 xs station wagon
Post #298165 12th Jan 2014 7:15pm
Criffel
United Kingdom 1994 Defender 90 300 Tdi HT Rutland Red
Entered my first TYRO and didnt come last! Very Happy 2011 D4 Nara Bronze
2007 Discovery Rimini Red. Gone. Thanks for the memories.
1994 Defender 90 300 TDI - Galv chassis
No one warned me Land Rover are not cars but an obsession!
Post #298182 12th Jan 2014 8:18pm
mk1collector
Checked the water leak work from yesterday and..........
It still leaks Big Cry but I found another crack in the sealer so tomorrow could be the day it's sorted Rolling Eyes
Post #298201 12th Jan 2014 8:54pm
BigRuss
Spent the weekend using the interior space to the max!
It's great to have cavernous space when transporting stuff Very Happy Russell
2011MY 110 XS USW Black
Post #298206 12th Jan 2014 9:05pm
Tiger
Towed my boat 220 Miles from Wales
Post #298351 13th Jan 2014 3:32pm
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Emptied about an inch of water out of the passenger footwell - again.
Post #298357 13th Jan 2014 3:47pm
DingoDad
England 1994 Defender 110 300 Tdi SW Blenheim Silver
Surprised you couldnt sail it from Wales with all that lovely weather! 94 Defender 110 Wagon
2012 Mini Countryman SD (Work Car)
Post #298359 13th Jan 2014 3:49pm
mk1collector
Fixed the water leak on the third try. Touch wood Embarassed
Post #298369 13th Jan 2014 4:09pm
keith
There wouldnt be any leaks ,,,, if it Was made of wood Rolling with laughter
Post #298374 13th Jan 2014 4:41pm
Kev stephenson
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
You haven't fixed it, it just didn't rain today. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
1996 130 300TDi chip truck for tree surgery business
Post #298776 14th Jan 2014 6:45pm
mk1collector
Rolling with laughter you might be right
Post #298815 14th Jan 2014 7:50pm
