Page 615 of 1379 <123 ... 614615616 ... 137713781379>
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
David I seem to have the same colour now as well lol
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #293891 29th Dec 2013 2:11pm
GUM97
Why don't Land Rover offer the 'Mud' colour as an option Laughing Laughing An engine to TDi for!
Post #293899 29th Dec 2013 2:52pm
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
Carried out some prep work before my 600 mile trip to visit the parents in Gloucestershire later in the week. Washed the outside, topped up oil, water, screenwash etc. Attached my new phone mount on the dash. Just got to check the tyre pressures next time I'm passing a petrol station. 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #293901 29th Dec 2013 2:56pm
Still continuing to change out bolts and screws for SS versions.
Made a cock up today though and by sheer miracle issues were avoided! Embarassed
I changed my heater intake screws on the wing and the blank screws too on the other side.
Of course I take out the factory screws from each side and put the on the top on my CP wing tops, and then replace them with SS screws.
Of course mugging here forgets he put the original screws there, then popped out with 7 screws placed on each wing without noticing!
Anyway finally noticed when I got to my destination about 2 and a half miles away round the lanes, and by sheer miracle they were all still where I put them! 7 on each side. Shocked
Shall have to try and avoid doing that ever again all the same. Rolling Eyes No Guts, No Glory.
Post #293908 29th Dec 2013 3:06pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Fixed the alternator and starter motor that floods and Salisbury Plain destroyed!
Post #293946 29th Dec 2013 5:02pm
Romadog
Had the first chance to test out my Mud demisters Thumbs Up
Post #293957 29th Dec 2013 5:21pm
Alex1976
Roma - are we to take it that the Mud Demisters are in the same league as a chocolate fireguard? Or are they the before shots and after are yet to follow?
Post #293967 29th Dec 2013 6:10pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Did you put the holes where they tell you to in the instructions? Mine work well but only with the fan on full.
Pete.
Post #293971 29th Dec 2013 6:22pm
bob neville
Tracked down the mysterious hissing sound that appeared Christmas day after going through a few big puddles in the red 90.
Turbo hose clip was undone and one of the bigger bow waves must have dislodged the turbo pipe.
2013 Defender 90 CSW - sold
Post #293972 29th Dec 2013 6:24pm
Romadog
Alex, considering the windows were covered in ice this morning they were doing a good job in defrosting. A bit pointless taking a photograph after the event !!
Pete, The holes are as instructions. The reason why they seem to work only on full speed is because there is such a large difference in blow between that and no.1. The side windows eventually demist with the windscreen vents , but these extras at the side just help to clear the front of the window, where normally only a cold draught appears from gaps in door seals !
Post #293982 29th Dec 2013 6:56pm
Lorryman100
davidwhittaker wrote:
Opted for a new 'desert camouflage' paint job
Looking at the above picture and the wiper pattern I am guessing that you will need to replace the wiper spindles soon unless you pull back the spindle rubbers and apply copious amounts of grease before reseating the rubbers. :wink:
Post #294020 29th Dec 2013 8:57pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Trundled over to the ford at Little Paxton near St Neots. Road closed due to flood so had to walk down to the ford to take a photo.
River was less than 1 foot deep was still very fast flowing so I can understand why it was closed after the last batch of rain. 1970 Series 2A 88"
Post #294021 29th Dec 2013 9:00pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Missing mine. Lots. Crying or Very sad It hasn't even left the country yet. Somwhere in Suffolk awaiting loading.
Oh well, 8 weeks and I'll see it again, hopefully in bright sunshine and about 20 degrees hotter than it is here! Very Happy Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #294288 30th Dec 2013 5:58pm
GEllis
England 2013 Defender 110 Puma 2.2 USW Indus Silver
Fitted door stay from Mudstuff, dynamat to side panels before the TGE internal protection. Plus a 12v aux socket and wound down the bolt stops on the steering. Thanks to forum members for tips on aux socket and bump stops made a big difference on turning circle.
Post #294379 30th Dec 2013 9:50pm
bob neville
Bob
Well, that was part of the problem !
Hiss had diminished but was still evident. Difficult to work out if it was actually hissing or a very light rattle.
Bonnet up and everything checked and nothing appeared loose. Ran the engine and there was a distinct exhaust gas smell in the engine bay. Checked the exhaust and it seemed fine. Started the engine again and I could hear a light tinkling sound above the cat on the drivers side.
The culprit was then found. The pre cat temp sensor had fallen out and the retaining nut was rattling against the heat shield. The exhaust smell came from the hole where the sensor should have been. Looking at the retaining nut it looks like it may never have been done up fully.
Wrestled the heat shield off and put the sensor back in.
The loose sensor may have been responsible for another problem since new, occasional lack of all power when pulling away first thing in the morning ?
After a test drive I can say it drives much better.
I will get it into the dealers in the New Year as the sensor did not look healthy and I am sure there are some fault codes logged that will need clearing.
Post #294613 31st Dec 2013 4:32pm
