![]() | Home > My Defender > What Did You Do In Your Defender Today |
Being a good samaritan is mainly down to be a good judge of character these days. I have driven on from various "incidents" over the years after making sure all parties are safe and secure as opposed to setting myself up for a fall. Don't get me wrong if somone is in need of help then I will give it willingly but I won't be taken for a fool.
Lewisgregory8 Member Since: 17 Sep 2012 Location: Durham Posts: 395 ![]() ![]() |
Take a look for yourself
http://www.defender2.net/forum/topic25142-90.html ![]() |
need some more silicone on the door rubbers ...cold here at the moment
Refitted my spot lamps and tested them after there dunking.
All good so went and topped my tyers up with air and fetched some concrete from B&Q to fill in a hole which appeard by the drive after all the rain had washed it out. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6169 ![]() ![]() ![]() |
Took my 110 off road.... first time in about 9 months as I've had a 90 to play in... was a strange experience...draught and rattle free!
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
cleaned the 90, and discovered the passenger door frame has fractured next to the button, which explains why it hasn't been locking properly...
![]() Anyone found a good source of galvanised door frames? Mark S CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
http://www.ashtreelandrover.com/Doors.html ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
ooh, thanks GUM, just need Santa to come round again soon.... Mark S
Evil SPECTRE agent German accent voice...... 364 days, and countinnnnnggg.... ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
went clay pidgeon shooting. what fun
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 ![]() ![]() ![]() |
Drove across to "Norridge" to specifically look at a 2009 SVX soft top @ £21K...
Trouble started when I quickly realised I didn't fit as my left knee fouled the dash ![]() I'm sure I could hear my TD5 giggling... TT "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1728 ![]() ![]() |
spent this morning fitting my heavy duty galvanised rear bumperettes which were a pain and then fitted 3/4 of the Gwyn Lewis front mud flap and spray plate kit. Really nicely made and look like they'll actually keep the sides clean, but also a bit fiddly!
Off to go and treat all the cuts and scuffs on my hands now where it claimed my blood ![]() |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
As the storms seemed to have cleared and I had some lovely sun and blue sky I thought I would crack on with fitting new front discs as the old ones were down to minimum 12mm. I had a set of proline drilled and slotted discs sitting in the shed ready so I cracked on. Half way through the second disc it went black and the gky unleasehed a full on downpour on me so I had to finish off the job getting cold and wet
![]() Should be all worth it when I drive it tomorrow though. |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
Nothing!
![]() ![]() I had planned to install my new C-tek charger and make some other electrickery modifications, but as I have to work outside it will have to wait until the weather is better. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
