![]() | Home > My Defender > What Did You Do In Your Defender Today |
mhmmmm where i have seen it??? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Went from this:
![]() Click image to enlarge To this, X Eng Defend column ignition barrel shield: ![]() Click image to enlarge Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Brian is it as easy to fit as it looks ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
It was an easy job Karlos, I have done a write up here
![]() http://www.defender2.net/forum/post194037.html#194037 Brian. |
good write up Brian, please keep us informed regarding this weeks testing
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Spent a good day on the Plain, very wet but hardly anyone else out there
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Today I had a go at replacing the rear output seal on the transfer case. Removed the prop shaft OK.
Then had fun and games removing the cross head screw holding the drum on. I had to break out the impact driver as head was starting to round off using a normal screw driver. Removed the 30mm nut using the buzz gun. Replaced the seal but think the seal is too far in, so may have to do it again! Did a tip run and washed the Landy 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
I washed the 90 yesterday.
Got it dirty today ![]() |
Skippy R Member Since: 08 Feb 2012 Location: Yorkshire,out 'n'about Posts: 160 ![]() ![]() ![]() |
![]() Washed it after doing a few little jobs, don't know why as it'll rain tomorrow now ! (That was a practice for loading photo's, never done it before ) ![]() 98 'S' 90 300Tdi (sold) 07 D3 HSE (now sold) 1993 Scania 143 450 (should have kept that ! ) |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
fitted my new lights, care of mobile centre, really pleased
![]() ![]() Click image to enlarge |
Shhh dont tell Lishlandy
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Ouch! Hahaha lets all laugh at Lish who can't join 2 wires together. Go on Lishlandy run to Uncle Ken when you can't complete a circuit.....
Although this is the new Oxford dictionary definition of 'all the gear, no idea'. ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20607 ![]() ![]() |
![]() At least you tried. ![]() ⛽️🛢️⚙️🧰💪 |
Failure is a mear temporary set back to success ===================================
