![]() | Home > My Defender > What Did You Do In Your Defender Today |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Intrested in a few lanes or weekend too
![]() Today, I have mostly been fitting a Luguage Guard. what a ![]() ![]() Also took out the centre cubby box, still laughing now at its construction ![]() |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
Thanks SEB! I have a lot of accessories in my garage to install, but I don't have time... This is what is waiting inside boxes... - CB Midland 78 plus multi + antenna Turbo - Stearing wheel Momo Tuner dim. 350 mm - Front + rear light guards by Equipe 4x4 - Tree slider Devon 4x4 - Chequer Plate Wing Tops Black Devon 4x4 - transmission guard Devon 4x4 - fuel cooler guard Devon 4x4 - Heavy Duty Front Turret Devon 4x4 - Scola shock absorber, adjustable compression and extension - tank guard by Equipe 4x4 and some others spares.... Matteo Defender 110 Td4 SE MY 09 |
Harvey They sure are ![]() Those pictures were at lunchtime when we had returned to semi civilisation. The tracks we spent most of the time on were rutted and very slippery and in one place involved winching. The land we were on is a private estate which Land Rover Experience has access to. We were looking for new areas that could be used for their adventure days. The only problem is that most of the area is forest and some areas we had to keep well clear of due to the disease that is attacking oak trees. If we had entered a contaminated area it meant that our vehicles would have to be steam cleaned before we could leave the estate. If you want to explore Exmoor try Land Rover Experience Honiton, a full adventure day costs £88 (I think) and you will go to areas that are closed to the general public. Bob |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
"What Did You Do In Your Defender Today"
Does 4000 miles and 2 weeks around Morocco count ?? ![]() ![]() Main Brian James Trailer Dealer for South West UK |
No ![]() Bet that was fun. Can you post any pictures ? Bob |
![]() Click image to enlarge ![]() Main Brian James Trailer Dealer for South West UK |
That does look like fun
![]() I will add Morocco to my list of places to go when I retire. Bob |
I installed my detroit locker in the rear axle off my 90. The True Trac still has to go in the front axle.
So more spanner time then driving time today. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Installed my new A4/map holder to the back of the cubby box
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
Bob dont wait till then do it now its the only way
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I like it, Tack. Where d'yageddit? |
i new this was the long drop
SEB, made it this afternoon as I was getting fed up with sticking the stuff in the cubby box with everything else that lives in there. Will get it powder coated with my other bits just to finish it off
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 ![]() ![]() |
Where did you get the A4 map rack from?
