Page 1349 of 1385 <123 ... 134813491350 ... 138313841385>
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
loving the new 130! - Added a flatdog roofrack which is excellent and no wind noise, added the Lazer bar on the front, new Darkside Intercooler and K2 Fabrication intake pipe. Getting the engine breathing sorted and new Stage 1 Ashcroft TC case before i take it to Empire Tuning for some remap majic.
Post #984026 1st Mar 2023 9:57am
LR90XS2011
fitted LED high level brake light
fitted WIPAC LED numberplate light
fitted new headlight levelling switch
fitted LOF clutch spring (went straight on!!) tried twice before and gave up, perhaps I was more motivated by a recently complaining knee
fitted stainless steel mud flap brackets front and rear DEFENDER 90 TDCI XS,
Post #984471 5th Mar 2023 4:07pm
Fitted a new battery:
More details here: https://www.defender2.net/forum/post984477.html#984477 Darren
Post #984484 5th Mar 2023 5:08pm
Shouldn’t think you’d be able to fit more in that battery box LRA if you tried. 👍🏻
How many CCA does that setup have approx? Must be over 1200A at least. WeWillWin🇬🇧🇺🇸
Post #984501 5th Mar 2023 6:36pm
Ha ha, there's lots of space really Laughing It's just a simple split charge system though, with no means of linking the batteries for starting. It's also getting ripped out when the weather warms up a bit, as I no longer need the second battery in the vehicle and the split charge will be replaced with something beefier. Darren
Post #984540 5th Mar 2023 10:10pm
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #984543 5th Mar 2023 10:28pm
Jabberwocky
Luxembourg
Changed Diff oil and greased the prop shafts in preparation for a road trip later this week.
Also checked the ECU for signs of oil creep, none detected, interestingly discovered my TD5 had a new ECU at some point, changing it from the MSB to the NNN type. I’ll have to get a nanocom on there to see if it’s running a different map or was just changed to NNN because that’s what they could get.
Post #984548 6th Mar 2023 1:38am
ChrisDefender
LRA, great tip on writing the install date on the battery Thumbs Up
I also put one of these in and it seems a much better start-up on cold days.
Post #984561 6th Mar 2023 10:40am
Thanks. Given the five year warranty on this battery, it seemed like a good idea. Darren
Post #984564 6th Mar 2023 10:57am
geobloke
Well the replacement front diff dance begins. Emails have gone out... Thumbs Up
I am almost tempted with a 4 pin front diff rather than an Ashcroft ATB as I have heard that having an ATB only in the front makes the Defender drive like a shopping trolley and as such is inadvisable.
Decisions decisions... Rolling Eyes
Post #984565 6th Mar 2023 11:03am
geobloke wrote:
... having an ATB only in the front makes the Defender drive like a shopping trolley and as such is inadvisable. ...
Whoever told you this has clearly never driven a Defender with an ATB in the front only, or is a moron. Very Happy
Post #984571 6th Mar 2023 11:36am
geobloke
Rolling with laughter Rolling with laughter I knew that would poke you Whistle
Post #984572 6th Mar 2023 11:46am
I forgot the "or both" option in my last post. Rolling with laughter
You will find plenty of people on here now, besides myself, who have nothing but good to say about an ATB in the front axle, but there are four-gear options which will be as strong, including the option of an air-locker, which unlocked behaves just like an open diff.
The two options you probably want to avoid are (a) fitting a two-gear standard Landrover diff, and (b) fitting a four-gear standard Landrover diff, the latter because they are as rare as hens' teeth and fiendishly expensive, more so than almost every other option.
Whatever you choose, swapping the front diff, whilst a bit more of a pain than the rear, can be done fairly quickly and without too much trouble if tackled the right way.
Post #984579 6th Mar 2023 1:20pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Winter Sawtooth/Hakkapelieards off
Summer setup balanced and installed
 Roaming around 🇳🇴🇨🇭
Post #984706 7th Mar 2023 4:10pm
StressedComa
2011 Defender 90 Puma 2.4 CSW Sumatra Black
I had my old Continentals replaced with some new Goodyear Wrangler MT/R I picked up from black circles for £116ea. Couldn’t quite stomach some KO2 at £100 more a corner. Wish I’d got five though now for the spare.
Post #987067 27th Mar 2023 9:28pm
