Home > My Defender > What Did You Do In Your Defender Today |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Well that's well smart! I like it, it didn't occur to me it would be an auto... Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
8th Jan 2019 9:16am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
try to find her Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
8th Jan 2019 1:18pm |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 823 |
First ever parking rules applied.
90td5 no Ac big muds and modulars Click image to enlarge I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
8th Jan 2019 1:57pm |
ah there it is... - didn't show when I looked lol Regards
8th Jan 2019 1:58pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Yes - had the full set fitted by Gwyn 4 years ago. When Zagato treated the chassis late 2017 he commented that the rear crossmember was in much better condition than many he had seen, so it's worth fitting rear of rear wheel protection as well I think. |
8th Jan 2019 2:03pm |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 |
Filled it with kit and went carp chasing !
Click image to enlarge Instagram; @gavin_walding |
9th Jan 2019 12:13pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5857 |
Order the bolts/nuts/bushes to replace the front radius arms and panhard rod.
Then that just leaves rear A frame bushes to replace Other that shocks, I can think of any more suspension bushes to replace. (rear trialing arms are done) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Jan 2019 7:16pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Love it GREENI, nice set up 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
9th Jan 2019 9:47pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
Yep, front and rear of back wheel and rear of front, plus detachable mudflaps for the rear. Good kit in my opinion. |
9th Jan 2019 10:33pm |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 726 |
Yepa.....
Looks good also |
10th Jan 2019 5:44pm |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
Finished installing the A bar with Lazer 750 spot lights.
Click image to enlarge |
12th Jan 2019 1:09pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Click image to enlarge Fitted a stainless steel grill. |
12th Jan 2019 1:58pm |
I like that bud! Looking smart! Regards
12th Jan 2019 2:16pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1848 |
Trying to kill some of the echoes from the cavern in the back..!
Lifted a couple of sheets of closed cell foam I'd put in years and years ago, and started laying some 3mm 'silent coat'. Once that's done I'll put the closed cell back on and stick up some carpet or rubber matting: Click image to enlarge Click image to enlarge Found these wee fellas under the foam - the rivets at the bottom of the bracing panel - they look pretty ferrous to me. Good old alli and steel! Is there any good reason they're ferrous, or could I put aluminum rivets in here? Click image to enlarge Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
12th Jan 2019 7:02pm |
