Page 1113 of 1382 <123 ... 111211131114 ... 138013811382>
gilarion
Cetane wrote:
AJC wrote:
Please tell me you don't wash it with a sweeping up brush!
gilarion wrote:
Looks like a bottle of Fairy Liquid at the side of the bucket as well Wink
It does look like a well cleaned machine though Thumbs Up
Its getting a full respray... so yeah I washed it with my truck washing brush and a bottle of fairy to get the Censored off.
It will be getting washed VERY carefully when it returns!
And thanks. It's my favourite money pit. Laughing Rolling Eyes
Wondered why the bumper and grills had been taken off a respray explains why. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #713457 20th Jun 2018 3:11pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Keith5 wrote:
Rosco - I See you're putting into practice the leaders advert Rolling with laughter :
Your right. Laughing Might have to get this one out at some point over the weekend
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #713467 20th Jun 2018 4:09pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Today I went to Blenheim Palace to place some generators around the grounds for lighting for flower show that's this weekend and was asked to fit a flashing light,and few months ago I went down to Mersea Island and towed some caravan about on one of the camp site's ,because it's a public area I had to have a flashing light.Where to fit one ? This was my solution was mount a steel plate on top of the RAI .Seems to hang on OK up 60mph .
Then went for a drive around the park
Post #713468 20th Jun 2018 4:20pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I need to find out where I get one of those. Keith
Post #713508 20th Jun 2018 6:26pm
JWL
Years ago when escorting farm kit around the roads I glued an old magnet off a cb mag mount on the underside of my Ifor Williams top making sure the thing was the right way round to attract the magnetic mount on the flashing beacon I used. It was quite impressive to just stand by the side and just chuck the flashing light on the roof and it would "find" its spot every time. It used to take some prising off mind Whistle
I'm sure it would be simple enough to glue a similar magnet under the roof lining to do a similarjob Thumbs Up
Post #713549 20th Jun 2018 8:34pm
excossack
Yesterday;
Replaced rocker gasket
Front cam seal
Oil change; Axles F&R, gengine oil and filters plus air filter.
Changed fuel filter.
Snapped one of the bolts holding the rocker cover in place, managed to remove this and replace with spare
Did the transfer case and then regretted doing it.
Noticed the drain plug was not very tight....on removal, some of the threads are damaged Sad
Managed to get a fix but a more permanent one is required. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #713827 22nd Jun 2018 9:21am
Took my daughter to a Jamboree Scout camp for the weekend and took a quick snap on the way out:
 Darren
Post #713937 22nd Jun 2018 8:45pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
I bet that lane gets a tad muddy in the winter 😬
Post #713938 22nd Jun 2018 8:53pm
legin
Today just keeping out of the sun
Post #713974 23rd Jun 2018 7:09am
excossack
Fitted spring isolators to the rear of the 110. Gave around 20mm lift. Will see how they go after a few miles of driving. 1999 Defender TD5 110
Regards
John M0VAZ
Post #714067 23rd Jun 2018 7:08pm
mk1collector
Which isolator did you use? The ones I found were only a rubber sleeve for the back which didn’t lift it more than a couple of mm. Ray
My build thread
Post #714097 23rd Jun 2018 8:46pm
excossack
These ones
https://www.ebay.co.uk/itm/LAND-ROVER-DISC...2749.l2649 1999 Defender TD5 110
Regards
John M0VAZ
Post #714098 23rd Jun 2018 8:48pm
Have you got any pics of the fitting? Those should be too small for rear 110 springs Confused Darren
Post #714099 23rd Jun 2018 8:51pm
mk1collector
I didn’t think they made that type for rear defender springs Ray
My build thread
Post #714102 23rd Jun 2018 8:54pm
excossack
No pics taken - sorry.
I thought they fitted OK. Certainly fitted in the top spring support OK and then spring appeared to sit OK around/below the ring. 1999 Defender TD5 110
Regards
John M0VAZ
Post #714104 23rd Jun 2018 9:03pm
