![]() | Home > My Defender > What Did You Do In Your Defender Today |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
Paul55
![]() 2008 SVX 90 2000 XS TD5 90 |
Don't know really. I do not use anything specific really other than a commercial rubber treatment spray or silicon spray, but not more than twice per year. My seals are all like new, no cracking or other aging signs at all. Now, 8.5 years old and 85K km, so it has been used. But, it never is parked really outdoors, I'd say 80% in dry garage, 20% under carport, limited direct sunlight, never at the seaside, so no salty winds. And it obviously is kept very clean. I don't know if some or all of those factors combined help keep it in condition, but nothing else I can think of really. Eric Edit - below is a picture of what I use a few times per year. But I have asked the question a few times if it is really effective to spray something on a thick rubber seal. It surely does not penetrate in our window seals, so is it really doing something? I never got a clear answer to that... ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 26th Feb 2017 6:51pm. Edited 1 time in total |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
I use some stuff I found in bedside cabinet for treating the rubber bits
Do Anne Summers do car cleaning stuff
![]() ![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
My youngest needs to learn to ride on two wheels this year so picked this 2nd hand bike up today in the defender for her to learn on
![]() ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5900 ![]() ![]() ![]() |
Started fitting a Albright, heavy duty master cut out solenoid into the battery box. Rain stopped play.
Gave the brackets for the dog guard a coat of primer and then a top coat - now drying in the shed. Removed the rear carpet and foam mat as water had made its way through the rear side windows ![]() Regards John M0VAZ Econet Station 48 no clock |
nicholas2012 Member Since: 28 Jun 2012 Location: lanarkshire Posts: 194 ![]() ![]() ![]() |
Took my old mk4 astra to the scrapyard today about 20miles away but ended up bringing it back with me as was abit too late, they closed earlier than i thought
![]() But got a good few waves off fellow defender drivers ![]() |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3810 ![]() ![]() |
My dad came round and what we call the 'bad garage' at the back of house where my New toy will go we changed the up and over door for barn doors... so it should fit in.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge So I then cleaned my other car and one of my dads ![]() ![]() Click image to enlarge |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2712 ![]() ![]() |
Nice. Though you've hung them back to front
oops really...
My dad did think about this for a bit and decided the way we did it... ![]() Oh well they seem fairly solid and look far better than the old up and over, Don't think is should make too much difference? ![]() |
ChrisWoods Member Since: 29 Dec 2016 Location: Spreyton Posts: 164 ![]() ![]() ![]() |
That's what I thought. Yeh, swap em over before too long. 2009 2.4TDCi XS Utility Wagon. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20654 ![]() ![]() |
It will drop, as there is no upwards 45 degree bracing to counteract the force of gravity. ![]() Typically there is a single upward facing brace or a K brace. I prefer the latter on gates and doors I've made before. A K bracing with triple hinges. But yes, swap those over. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Your braces are operating in tension, whereas you want them working in compression.
Swap them over and put three hinges on each - in line with and attached to the rails, not the panelling. |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3580 ![]() ![]() ![]() |
Hope the John Deere pedal tractor gets a new home when it is evicted?
