Home > My Defender > What Did You Do In Your Defender Today |
Above picture seems to show the wrong indicator position. Defenders should have indicator at the outside. Easy to swap over as below. Click image to enlarge Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
15th Feb 2016 7:41pm |
Eric you are a card, you know very well ... Factory position is as the ice photo, you must have moved yours
15th Feb 2016 7:45pm |
A card? I don't do Valentine cards. But intrigued by this expression which is beyond my level of English, I went googling it and found this explanation here... "You're a card" means you are the key to a solution". I can live with that. Correct position for a Defender indicator is as in below picture, the outside. For the SVX, the ICE, RAW, Adventure, Autobiography, etc. Solihull decided to move the indicators to the inside for cosmetic reasons as they found the filament bulb indicator lamp did not look right at the outside in combination with the rear/stop and the reverse and rear fog lights which are all LED, so they just put the rear fog and the reverse at the outside, leaving the LEDs in a vertical line. When replacing the indicators by LED as we did, it looks better when you put them in the correct (meaning the standard) outside position of all other Defenders. Eric Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 15th Feb 2016 8:52pm. Edited 5 times in total |
15th Feb 2016 7:57pm |
And, finally good to see that at the other side of the North Sea there is at least one Defender with the steering wheel on the correct side.
But, ..... for that huge A-plan sticker in the window you probably would be fined here as it would be seen as blocking too much of driver's view. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
15th Feb 2016 8:01pm |
Thor's on the ball, tis an old photo, I have a Startech fitted now and rfl has been removed
15th Feb 2016 9:34pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2882 |
Love the seats!!! Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
15th Feb 2016 10:29pm |
^^^^ thank you sir !
15th Feb 2016 11:02pm |
Thinking of getting the rears water carbon dipped ...
15th Feb 2016 11:03pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Nothing to exciting but fitted the Foxwing as first camping session is in Easter 😊
16th Feb 2016 8:11am |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 815 |
Put the fan heater in the v8 soft top for 30 mins this morning just to defrost it and warm it up for the 5 min drive to work. The electric probably cost more than the fuel ( well in the case of the v8 I'm not that sure ) but it was worth it 😀
16th Feb 2016 3:14pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
POST MOAR PICS,painted loads of these in the eighties,along with Fiesta Supersports (and Escort mk2,1600 Sports)!!Pretty sure we saw most of the Fiesta Supersports ever built. For the kiddies today,in them days a 10 yr old car was absolutely,utterly rotten thru (if you were lucky). Fake edit;was removing the plastic body kit on a mk1 turbo (wheel arch extensions,front/rear "spoiler" kit)drilling the old (plastic) pop rivets out,went right thru the windscreen washer bottle,lol,tucked behind the N/S front wing,dint say a word about it.....No wonder I dont trust anyone to work on my car,lol. Pov.spec,ftw. 2006, 110,TD5. |
16th Feb 2016 3:48pm |
Also,the captive nut and bolt arrangement on them Fiesta Supersports back/front bumper have more than likely been replaced with non-captive nut and bolt....28 years ago . Pov.spec,ftw. 2006, 110,TD5.
16th Feb 2016 4:02pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
Ordered new engine mounts after finding about 10mm of play in them yesterday whilst swapping engines. I reckon two blokes could swap a TD5 or do a clutch in 5/6 hours if they knew what they were doing. Fun!
17th Feb 2016 10:54am |
jb71 Member Since: 11 Jul 2015 Location: East Sussex Posts: 103 |
Jimbob7 and AJC . Very nice!
I've a Mk1 XR2 at the back of my garage in need of some TLC. Owned by me for 24 years and before that was in the family from new. Would love to get it back on the road one day.... Not sure I've the skills though. |
17th Feb 2016 12:56pm |
