Home > My Defender > What Did You Do In Your Defender Today |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 913 |
Added a little bit of extra front lighting for those dark country lanes.
Click image to enlarge |
5th Dec 2015 4:14pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Installed my full set of RDX LED lights.
Not a bad job TBH the results are very good. |
5th Dec 2015 8:46pm |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Smart looking light mate ...
5th Dec 2015 9:48pm |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 263 |
o.kv
read a few forum topics on changing gearbox oil and filling swivel housing with grease ....got stuff ready 1). 3 ltrs difflock eb=volution1 synthetic oil 2). T55 1/2 in beastie to unto filler plug 3). 32 mm spanner to undo drain plug 4).Couple of sachets of one shot grease 5). Draper oil suction pump 5). might as well replace tht dead reversing bulb while I'm at it. Under car, undo filler plug .... and get that warm feeling of liquid runnng down my left arm. Oh yes, hard standing outside garage has a lean to it ... the wrong way o.k. lets drain this ... so wheres the 32 mm drain plug ? ...nope its a 1/2 in square hole threaded plug .... needn't have bought it .... guess an R380 gearboc is different to an LT77 managed to get about 2.3 ltrs into it before it starrts leaking again .... coz its on a slope. Tighten up everything and drive 1/2 mile to village hall which does have a flat area infront of it. Get another ~400ml into it. Job done. Swivel housings :- o.k these haven't had anyone near them for a while get the "bit of pipe" out for these occasions to shift filler plug. One shot grease in boiling water for a while went in a treat. o.k. now for the simple stuff undo reversing light .... need to remove the light protector covering all the LHS coz I can't get the light fitting out without doing that. does it work ? course not, its something else. Just as I was refitting the light protector .... the top of the license plate light fell off. Well wanted an LED one after all. ok.. that's that one done. not for the Series 3 ...... Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
6th Dec 2015 6:15pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Another milestone!
Click image to enlarge I did spot 170k but was driving along the M20 but didn't think taking a photo would be a good idea so waited till I could pull off safely. Roll on the next 170k! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
6th Dec 2015 7:05pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1640 |
What on earth happened! Where did that 'new' seat come from!! You must be furious. YOLO... You Only Live Once... |
6th Dec 2015 7:39pm |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 |
It looks as though the quality control went missing when mine went though. I don't want to publish the name of the company as they do not have a right to reply on here. I was rather bad tempered when I found the problems having waited 5 weeks for it to arrive. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
6th Dec 2015 8:54pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Used my rivnut tool for the first time to insert new riv nuts for the refurbed light guards to be fitted. A lot easier than I thought it would be don't know why I have been putting off drilling out the 2 old rusted rivnuts and doing this for so long.
Any way newly powder coated guards where fitted with stainless fitting including p clips as I don't like the plastic ones and I am very pleased with them now considering when they came off they where rusty and flaking their plastic coating. Click image to enlarge Click image to enlarge Click image to enlarge |
6th Dec 2015 9:17pm |
Very balanced of you mate... Just a PITA I am sure! YOLO... You Only Live Once... |
6th Dec 2015 10:17pm |
p_jeeeee Member Since: 08 Jan 2012 Location: Flanders Posts: 75 |
Fitted my KBX grill and removed the lightguards to powdercoat them.
6th Dec 2015 10:42pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5815 |
Ordered a Blacksheep rear x-member for the 110 1999 Defender TD5 110
8th Dec 2015 2:16pm |
I'm been down the tip.
8th Dec 2015 2:55pm |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 |
Click image to enlarge Click image to enlarge Got my Christmas 🎄 tree |
8th Dec 2015 3:14pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1715 |
Got mine back from its MOT passed with flying colours and loaded up with its spare parts for the new owner to collect
Also booked the ferry to Holland next week to look at its replacement |
8th Dec 2015 3:46pm |
