![]() | Home > My Defender > What Did You Do In Your Defender Today |
Qanfud Member Since: 24 Sep 2015 Location: Sliema Posts: 38 ![]() ![]() ![]() |
A picture says it better:)https://www.defender2.net/gallery/albums/userpics/19115/thumb_image.jpeg
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
You'll probably be OK without the infamous top bolt, the large majority of them on Td5 starters end up chucked over the hedge! My last D2 never had one on, no problems in close on 100K miles in my ownership. Most people use a 5" ish 3/8" extension and wrench if they bother from what I've read.
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
spent 2 hours off roading around the countryside in the pitch black searching for my young Labrador that bolted chasing a hare! found him on a roadside!
![]() my youtube channel |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
That's good to know. O.K. I'll have anoher try at tightening it tomorrow and if that don't work I'll judt have to wait and see what happens Thx A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20661 ![]() ![]() |
![]() Well done! One of ours did that once but never had the chance again. In the mean time a nice extending lead might be in order. ![]() |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Spent a wonderful good couple of hours stop starting around the M25 & Northwards on the M1...
![]() Driving my 110 Keswick Special for the first time as I trekked home... ![]() ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge Rog... ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 924 ![]() ![]() ![]() |
I'll let the picture speak...
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5900 ![]() ![]() ![]() |
Yesterday I was at the 60th year of the Cambrian rally. I was based at one of the Penmachno stages, on recovery duty.
Onto stage pulled a P38 2.5 followed by a cloud of steam from under the bonnet. Turned out top hose had popped! The owner soon got the hose cut down and refitted but needed water. In the back of the 110 was 5l tub of old tap water (certainly not drinkable) so that got donated towards the P38 and also 1 litre of Porsche antifreeze/coolant which had been in the back of the 110 for the last 5 years or so...just in case! No recoveries to do on our stage, so we went into the previous stage to lend a hand, but only one left and that was a Micra nose down into a ditch. With a quick tug from another 110 the Micra was out. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Fixed a mates turbo hose and had a good defender natter
Did a tip run.
Replaced the drivers side door switch. Serviced the 110. New oil filters, air filter, fuel filter and new oil. Cleaned the engine down to try to track down the oil leak(s). Started off with a garden sprayer and some Roc degreaser and got the pressure up on the sprayer and proceeded to jet wash the engine starting at the top and then going to the bell housing and surrounding area. Finished with the Roc degreaser and then added to the sprayer some washing up liquid and some boiling water. Again pressure up and sprayed the engine down. Quite a lot of the gunk came off and then did another kettle full into the sprayer and gave it one last wash with hot water. Engine now cleaner. Fingers crossed I can track the leaks. The two main areas I think are; Rear half moon on rocker gasket (yet again) and front cam seal (yet again) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Took the dogs for a walk up the hills behind Newcastleton in the Scottish Borders. Obviously we got there by Landy, a cracking wander on a cracking day.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3810 ![]() ![]() |
Sorted my squeaky clutch pedal with Instructions on this site,
6 screws holding the clutch cover plate under bonnet, 3 in 1 oil and grease. Squeak gone Ace |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
And I was the only one whistling on the way home! Russell 2011MY 110 XS USW Black |
Derrickthedefender Member Since: 28 Jan 2014 Location: South Posts: 294 ![]() ![]() ![]() |
Put my pride and joy up for sale
![]() ![]() Yes the name for my 90 is Derrick! |
