Page 809 of 1379 <123 ... 808809810 ... 137713781379>
Nice one - it's worth me spending 10 mins investigating that one - thanks for the idea Thumbs Up
Post #422199 9th May 2015 10:51am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
New tyres
Replaced the XZLs with new "take off" wheels and Michelin Latitudes on which I got a cracking deal from Tim at Marple road garage. The new tyres are so much quieter than the old MOD spec muddies, what a change. So this alteration to the motor actually makes it look more 'factory' than modded. Replaced the rear wiper blade whilst the spare wheel was off too. Then off to the local sawmill to get ply to make a base for the roofrack. After a lot of cutting and drilling holes, the wood now fits the rack very nicely. Need to give it a good coat of paint before it becomes permanent on the roof. Fuelled up today too, noticed I am 5mpg down on my last tank, the only change has been to fit the roofrack - does it do away with 5mpg Shocked If this is the case it might well be getting lifted off when I'm not using it.
Post #422280 9th May 2015 9:49pm
shaggydog
That wouldn't surprise me for a big heavy Brownchurch style one but I would be surprised that taking off the tyers for more road bias ones. Have you checked the pressures?
Try running it for a month and then have another look - a lot can influence your MPG.
I had a week of really bad traffic jams on my commute to work and my MPG dropped from 33-34 to 26-27 which terrified me, but then sitting at 0 on tick over for ages will give you a cruddy mpg. it perked back up when I found a different route so its not permanent.
Looks great by the way Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #422282 9th May 2015 9:57pm
RoddyK05
Cheers Shaggydog, yes I'm quite happy with the way it's looking at the moment. First fuel up was with the XZLs fitted and no rack. Got 30mpg on that occasion. Fitted the Brownchurch rack (was still on the XZLs) and it dropped to 25 mpg. Now that I have fitted the Latitudes I am expecting a slightly better figure next time, but not by a great amount. I don't do a massive milage - 3k last year - so it's not going to cripple me losing a couple of mpg, but it's interesting to keep a record of what changes to the motor can affect the fuel figures. The rack is there to be used so I guess I'll need to live with the drop in economy, but if that was my main concern I wouldn't have bought a 90 Laughing As I said, if it looks like there will be a long period where I'm not using the rack I could lift it off for a bit.
Post #422288 9th May 2015 10:10pm
shaggydog
Sounds entirely sensible and reasoned mate Thumbs Up
I keep quite a good eye on mine as I average about 300 miles a week so I get through a fair amount of diesel a year! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #422289 9th May 2015 10:19pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Yesterday i removed the engine to sort out the power steer pump bracket holes on the timing case ( one smashed off and the other had stripped threads ) then set about making a flywheel locking tool so i could undo the damper bolt to remove the timing cover, plan is to clean up the face of the damaged hole then re-drill and tap to 10MM if the timing case is thick enough and locktite studs in Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #422347 10th May 2015 9:31am
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Must workout how to sort this out?
Post #422644 11th May 2015 12:49pm
SailingTom
Roddy your 90 looks fantastic in yellow Thumbs Up
Met Pjh and son on sunday to collect a couple of bits, managed to get the cubby box fitted today as the old ones corners had worn through and mounted on some wood to raise it up.
Gave it a wash and wax aswell Smile
Post #422663 11th May 2015 2:34pm
RoddyK05
SailingTom, thanks very much. It's getting a wee bit done every now and then, just to get it the way I am happy with it. New seats should arrive tomorrow, possibly fitted tomorrow evening - but my good Lady wife has ideas for me that involve a steamer and a paper scraper Shocked If the weather is decent I'll play on her good nature and tell her I need to get the seats fitted before the rain starts, but we'll see. I like the look of your 110, very purposeful. I had initially been looking for a LWB, but the wife suggested a 90 might be easier for her to drive. As I'm keen to get her to use it too my decision was easily swayed - but she's not yet sat in the driving seat Mad Not to worry, I'm very happy with it, I suppose having the 90 with reduced space inside means that I need to keep it tidier Laughing
Post #422775 11th May 2015 10:11pm
cornish rattler
Sort what out Confused Graham
Post #422837 12th May 2015 10:43am
cornish rattler
Sorted the power steer pump hole out on the engine, had to drill / tap the damaged hole to 12MM in the end as it was to far gone to go to 10MM then just drilled the stripped hole deeper and stayed at 8MM seems solid enough ( loctited them in aswell ) Mr. Green Graham
Post #422840 12th May 2015 10:47am
excossack
The dented pipe on the right? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #422856 12th May 2015 11:34am
shaggydog
If your lucky Steven you may be able to undo the other ones bolts and then remove the water pump. Then heat it up with a blow lamp and then let it cool. Then try and get a good pair of Stiltons on it and wind it out, or if you have access to a welder, weld a nut on the end of it then gently try and and unwind it with a good fitting socket.
Failing that, buy a left handed drill bit no bigger than half the thickness smaller (ie if its a m8 bolt no bigger than 4mm) and drill into the center of the bolt - the heat will help crack it off and the the anticlockwise rotation will help wind it out. Just go carefully!
Good luck! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #422859 12th May 2015 11:40am
steventheplumber
Thankyou shaggy, spot on bit of a headache. But still drives like a dream.
Post #422919 12th May 2015 3:05pm
kipperthedog
Did the VW99 wiper relay mod. £1 and 5 minutes. Big improvement! Highly reccommended,
Very Happy
Post #422992 12th May 2015 7:16pm
