![]() | Home > My Defender > What Did You Do In Your Defender Today |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Took the G4 for a little run, nothing exciting
![]() Click image to enlarge Found a small mound of stone to play on! ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Fitted the side steps I bought off fellow forum member Waldo a couple of weeks ago.
![]() Click image to enlarge Drivers side. ![]() Click image to enlarge Passenger side. ![]() Click image to enlarge These were a really easy fit probably took longer to remove the excellent packaging they came in than to fit them ! Was also an good excuse to get the spanners out too,don't do to much of that these days. 2005 Td5 90 XS Steve |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
Finally got the roof rack installed back on the roof of the Landy after it was stripped and powder coated.
Next on the list is, attached the four spot lights to go on the front of the rack.(2 x fogs and 2 x spots) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
THF Member Since: 18 Jul 2012 Location: Sunny N Hants or Pompey Posts: 83 ![]() ![]() ![]() |
Braved the Bank holiday traffic in order to move jobs, with the help of a 110 and a newly painted sankey trailer!
Didin't realise I had so much kit, thank God for the trailer, it was full along with the back! ![]() ![]() ![]() |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 ![]() ![]() ![]() |
I spent all day Sunday and Monday cleaning and treating the chassis of the 130.
I used a ph neutral snow foam and jet wash to start the process, followed by Bilt Hamber Surfex HD (undiluted) to get rid of the grease. Once the chassis was dry I filled all of the voids I could find with Dynax S50 before applying four cans of Dynax UC to the outside of the chassis, axles, springs and other hardware. I'm not certain that the application of S50 was comprehensive (I used 3 750ml cans but a lot of that ended up in the road ![]() I'm hoping that I won't have to do that again in a hurry... |
90mojo Member Since: 19 Mar 2014 Location: UK Posts: 175 ![]() ![]() |
Picked up my Landy from Joe at JR Classics this morning. Had a thorough Dinitrol treatment. Very pleased with his work and a thoroughly decent person to deal with. Well happy
Not today but yesterday, another trip from home to work then to Canterbury with the girlfriends metalwork.
Journey from work to Canterbury was gorgeous driving along in the sunshine but the journey home had to go via the M25 because of road closures so made an extra 25 miles on the journey. Still cruising along at 55 listening to my music on an empty motorway was lovely! Then this morning my hour commute took 2 and a half because of a crash on the A21. Spent a hour sat with the engine off waiting for the police to clear up the mess though did take in the surroundings and make another mental list of "To-Do" |
Started to repair the rear passenger door. Plenty of rust to sort out.
Bottom of the door ![]() Door frame behind the door card. ![]() Rust removed ![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock Last edited by excossack on 7th May 2014 4:15pm. Edited 1 time in total |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 617 ![]() ![]() ![]() |
excossack: What do you plan to do to the doors, repair/replace?
Repair. The repairs have started. If the rain stops, I might just post a pic of the one section that has been repaired.
I did find there is a central brace that runs across the middle of the door that had also rotted away so that has been cut part way across and a new section of out of 1mm zintec plate has been shaped (well almost the same shape) that will replace the rusted section. The section behind the door car has been cut out and a plate made to fit in the gap which fits OK, just needs the rear side painting and then welding in tomorrow (if the rain stays away) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
More door repairs. Got a time slot with no rain, so out with the welder and grinder.
![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock Last edited by excossack on 9th May 2014 1:59pm. Edited 1 time in total |
Jambo Member Since: 30 Apr 2014 Location: Sunny somerset Posts: 13 ![]() ![]() |
Took the dash out my tdci 110 double cab
![]() ![]() ![]() ![]() ![]() Also how easy is it to retro fit electric windows ? and is possible to fit central locking that works off the same fob as the alarm ? Many thanks James |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1725 ![]() ![]() |
Took it to the local garage as had the engine light come on, turned out it was just the airflow meter so will keep an eye on it but seems ok now. Also ticked over to 10,000 miles! hopefully ill have many more
Got the paint on the door repairs. Looks better.
![]() Click image to enlarge# Just the remaining doors to inspect/fix and new door fixings to order to replace the broken fixing. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
