Home > Puma (Tdci) > Remap and noises after engine shutdown. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Induction noise will not really change – well, not a noticeable amount. However removing the EGR does actually increase combustion noise slightly… With regards to turbo speed… The above theory above relates to fixed geometry turbo, not a variable geometry turbo – and especially one running an ERA (Electronic Rotory Actuator) – where by angle is controlled by the ECU. You would account for changes to the air path in the calibration - as you are no longer running EGR (100% of air will now pass through the MAF sensor) – and you would also make changes to the turbo map to make sure the turbo is running at the correct speed. In simple terms you would adjust/trim the vain angle of the VNT mechanism to make sure the exhaust wheel speed remains correct - so at idle (etc) it would be the same as standard. This also true with regards to modifying the exhaust/adjusting back pressure. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 Last edited by Porny on 13th May 2013 2:15pm. Edited 1 time in total |
13th May 2013 11:28am |
Yep, all that makes sense
No exhaust mods on mine. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
13th May 2013 12:11pm |
