Home > Puma (Tdci) > Remap and noises after engine shutdown.
Page 4 of 4 <1234
Porny
Site Sponsor
blackwolf wrote:
When on tickover with the EGR open, the engine will be drawing in a certain volume of intake gasses, some of them from the air intake and some via the EGR. The engine will then be exhausting a significantly greater volume of exhaust gasses, some of which will be diverted from the exhaust manifold back to the inlet via the EGR, the remainder being passed though the turbine side of the turbocharger to exhaust to atmosphere.
If the EGR is shut with a map, even though there is no design change to the operation of the turbo at idle, assuming the same tickover speed the engine will be breathing the same volume intake gas and exhausting the same volume of exhaust gas. Now however all this intake gas will be coming via the air intake, hence the potential increase in induction noise as explained so well by Pete above, and significantly *all* the exhaust gasses (rather than just a proportion of them) will be passing through the turbine. A result of the gas laws will be that the velocity of the exhaust gas under these curcumstances will be greater than with the EGR open, hence the turbo will be spinning faster than it would be with the EGR open. Consequently if you shut down the engine the inertia of the of the rotating components will result in a longer spin down time. Inevitable. Either live with it or don't ness with the EGR! If you have changed the exhaust system (eg a de-cat or silencer removal) to reduce back pressure the effect will be exacerbated.
Induction noise will not really change – well, not a noticeable amount. However removing the EGR does actually increase combustion noise slightly…
With regards to turbo speed…
The above theory above relates to fixed geometry turbo, not a variable geometry turbo – and especially one running an ERA (Electronic Rotory Actuator) – where by angle is controlled by the ECU.
You would account for changes to the air path in the calibration - as you are no longer running EGR (100% of air will now pass through the MAF sensor) – and you would also make changes to the turbo map to make sure the turbo is running at the correct speed. In simple terms you would adjust/trim the vain angle of the VNT mechanism to make sure the exhaust wheel speed remains correct - so at idle (etc) it would be the same as standard.
This also true with regards to modifying the exhaust/adjusting back pressure.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #235134 13th May 2013 11:28am
Happyoldgit
Yep, all that makes sense Thumbs Up
No exhaust mods on mine. Steve.
http://forums.lr4x4.com
Post #235142 13th May 2013 12:11pm
Page 4 of 4 <1234
