Home > Puma (Tdci) > Remap and noises after engine shutdown.
Page 1 of 4 1234>
Happyoldgit
Having decided to hang on to my 110 XS USW for another year and as it is now out of warranty I decided to treat it to a remap from Pete at BAS. I'm happy with the results but puzzled by what appears to sound like the turbo winding down for a quite a few seconds after the engine is shutdown from idle. Obviously the EGR is no longer doing it's chuka chuka song which may have hidden other sounds but I have confirmed that the winding down is not present after I re-installed the standard tune, with the remap I get the noise from the turbo area.
I contacted Pete about this but we are both puzzled by the phenomena. Everything is functioning as it should, performance is just as it always has been, no smoke and there are no other strange noises or dodgy fault-codes.
Ideas on a post card please Wink Steve.
http://forums.lr4x4.com
Post #234060 9th May 2013 11:55am
barbel jim
silly suggestion, not the rotary oil filter spinning down ?? not sure if you have one on the 2.4 so Embarassed if you don't
Post #234066 9th May 2013 12:06pm
Porny
Site Sponsor
All down to turbo speed and spool down....
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #234119 9th May 2013 2:54pm
Mine does the same, I never noticed the sound before the no-egr remap. Assume it to be the turbo.
Post #234124 9th May 2013 3:11pm
Happyoldgit
Ian
That's what I thought, it doesn't do it with the standard map. Missus commented on it getting out the vehicle t'other day and it must be loud for her to notice. Steve.
Post #234128 9th May 2013 3:19pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Does that mean the turbo is spinning faster/working harder than with the factory software?
Post #234130 9th May 2013 3:21pm
Porny
Site Sponsor
In this case it's running faster than standard when it comes down to idle/shutdown... hence why it spins for longer than with a standard calibration.
Ian IRB
Post #234299 10th May 2013 6:41am
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
That will mean a new Turbo sooner rather than later then...bearings just love to run without oil ! You only have one life, live it....forget the cost.
90XS Hardtop
Post #234332 10th May 2013 10:05am
Happyoldgit
That is what is in the back of my mind too. Steve.
Post #234339 10th May 2013 10:26am
RobKeay
Would this mean you should let engine tick over for a minute when you have stopped. To keep oil running round turbo.
Post #234344 10th May 2013 11:34am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I know technology has changed over the years, but I was always told to keep the engine running a short while after the turbo had stopped for this very reason. When we had Auxiliary Turbo Engines that were running at 4,000rpm 8hrs/day we would have to leave them on low revs for about 10-15mins. You could always tell which operators didn't as they would get through more Turbos than those that did.
Post #234348 10th May 2013 11:43am
Happyoldgit
Yep, I generally do that. Steve.
Post #234349 10th May 2013 11:45am
mk1collector
I think you can get certain car alarms with the spool down feature so you don't have to sit in the car which could be worth thinking about.
Post #234352 10th May 2013 12:17pm
bell-auto-services
If the car is at idle speed, standard map the turbo is spinning at X speed and the egr is open and the air breathed is coming from two paths. The exhaust gas via the egr and rest the air intake via the turbo.
If the car is at idle speed, tuned map, egr closed as its deactivated. The air now is only getting breathed from one source. The air intake so induction noise may and will differ from a egr on car to a egr closed car.
This of course goes totally out of the window if you are just tuning the engine off while its still revving after pulling up in the car and not letting it idle first.
For reference the turbo vgt position on a standard and tuned map at idle is the same start point. Hope these words help the understanding.
Pete
Post #234432 10th May 2013 6:34pm
borderterrier
Hence my question. The longer term issues may end up outweighing the initial buzz that comes with a remap.
Post #234449 10th May 2013 7:29pm
Page 1 of 4 1234>
