Home > Puma (Tdci) > Rear Diff oil leak
Vera
2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Rear Diff oil leak
Noticed the other day what looks like a reasonable significant leak from the propshaft joint on the rear diff. It's booked into GSLR on the 15th, but I want to make sure there is enough oil in there for the time being.
I know it takes 1.7l as it retains a bit when you drain, but the question is, how do I work out whats in there and how much to top up?
On other cars it was simply a case of filling until the oil was level with the side filler... But is this the same with the Landy, or am I safer draining it all then refilling with the requisite 1.7l??
Cheers all... '09 SVX #200
'10 Morphy Richards.. I mean Prius
Post #232444 3rd May 2013 2:51pm
MartinK
The workshop manual says:
Quote:
3. If necessary inject new oil until oil runs out from filler/level hole. Allow excess oil to drain and wipe clean.
For additional information, refer to: Specifications (205-02 Rear Drive Axle/Differential, Specifications).
So you're safe to top-up to the level plug. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #232464 3rd May 2013 4:17pm
Also depends on the amount and frequency that it's leaking also. Mine was only the odd drip occasionally and was okay for a couple of months. I did get it fixed though and it fine now. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #232476 3rd May 2013 5:10pm
RED-DOT
Check the axle breather is not obstructed as the axle will have pressure when hot and cause the seal to leak. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #232796 5th May 2013 9:42am
