![]() | Home > Technical > turning off TC - PUMA specific |
I probably posted that. Even in a Td5 the TC would be switched on again as it switches on automatically above 7 km/hr I believe.
Not knowing the exact situation when you got stuck, but I don't think you got stuck because off the TC. I honestly think if you didn't have TC you would even come that far up the hill you came now. The only solution is fitting lockers. Locker work directely preventing wheelspin, not fighting wheelspin like the TC does. And it doesn't consume power. I think you can pull a fuse but I am not 100% sure you won't get faults showing up. If pulling a fuse works you could make a switch, switching TC and ABS if you don't want it and switching it on again when you want it like on the road or if you go down a hill. But coming back to what I wrote earlier I don't think switching TC off will help you off-road. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8202 ![]() ![]() ![]() |
Roel, not to disagree with you but being an off road driving instructor and making a living from it believe me it was the TC that stopped me getting up the hill. i dont want to get into the pros and cons of TC i am well aware of them i just want to know how to turn it off. Cheers
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
I think you can just pull the fuse and all is fine
Jst,
Like I said I don't know the actual situation but I am still confinced that say in 99% of the 100% TC will help you. I have been a LRDE instructor but not anymore as working in the oilfield pays a lot more money. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
If it's as simple as pulling a fuse, does that mean we could put an interrupt in line and have switchable TC?
That might be quite fun (although my off-road skills are not sufficiently good for me to ever turn it off, I suspect). ![]() + New Defender 110 First Edition |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Pulling the fuse out off road is a possibility, but just as a warning about putting a switch in- TC to an insurance company is a 'safety feature' and making it switchable might make it invalid.
Glyn |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2682 ![]() ![]() |
I can vouch for JST getting stuck. Even my D3 couldn't pull him up the hill
![]() Surprising how fast little dips can appear under your wheels when try to pull a 110 uphill ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
3WHouse Member Since: 24 Jan 2008 Location: Msk Posts: 70 ![]() ![]() ![]() |
The burnt down block is guaranteed.. Def`s 90 & 110 Monochrome. You can go fast i can go anywhere.)) http://www.offroadpower.ru/ |
Please explain ![]() |
Only full deenergizing of the block.)) ![]() ps: It already the second block (bloсk tc/abs 2300$ in russia) pps: Before switching-off !To switch off the motor! ![]() You can go fast i can go anywhere.)) http://www.offroadpower.ru/ |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
When we blew the front diff in Morocco we had to pull the TC fuse then the ABS started playing up so we removed that fuse as well. Or was it the other way round. Cant remember now is was a few years ago.
zeerover Member Since: 11 Jan 2009 Location: Ghent Posts: 17 ![]() ![]() ![]() |
Did it work? Putting the fuses in, is the only thing to do ? |
i agree totally, buts its that 1% were i would like the option!! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
First way ![]() |
