Home > Puma (Tdci) > NEW GEARBOX |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
my click went with the new propshaft and second gear issue with a new selector Mike
27th Oct 2009 6:59pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2411 |
Sorry, but what do you call a "selector"? thanks M Puma 110" SW ............................................................. Earth first. Other planets later |
27th Oct 2009 7:15pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Hi MK, its a plastic thing under you're gear levers thats connected to the gearbox that helps you select 1/2/3/4/5/6 and reverse, NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
27th Oct 2009 8:24pm |
Ok. Thanks. I also have a rough 2nd gear. But only when shifting from 1st to 2nd not from 3rd to 2nd Puma 110" SW
27th Oct 2009 8:29pm |
MK see your dealer now so if it gets any worse you have already told them thats how mine started, don't mean to worry you but get it logged NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
27th Oct 2009 8:39pm |
I´m going step by step. I´ll get a new TC as it clonks too much since 6000 miles.
Stealer already changed the clutch assuming that is the cause of the dodgy 2nd.....I guess next is the GB time. Puma 110" SW ............................................................. Earth first. Other planets later |
27th Oct 2009 9:01pm |
NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
27th Oct 2009 9:34pm |
Hi All, Had gearbox replaced today mmmm ? well its no better than the last one, or it needs to bed in im not to sure though, any one had a new gearbox and it's had to bed in or am i just hoping. Also had clutch replaced as Andrews mentioned there was a noise when turning it off thanks Andrews for that. But now when pushing the clutch in it seems weak very slack any ideas NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
30th Oct 2009 7:09pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I think the newer clutches are much lighter. Is there any chance that it is just that? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
2nd Nov 2009 10:17pm |
Problem from 1st to 2nd solved with a good gearbox additive......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
2nd Nov 2009 11:15pm |
I googled for "a good gearbox additive......" and there were too many choices. Puma 110" SW
2nd Nov 2009 11:24pm |
Yes that is what it is the clutch is just lighter and the gear box is a lot better now i'v done a few miles on it NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
3rd Nov 2009 8:05am |
Sounds like you're just suffering from 'progress' One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
3rd Nov 2009 9:59am |
FINGEAR or Bardahl T&D Polarplus (I used this one) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Nov 2009 10:12am |
