Home > Technical > Is your clutch on the way out
Page 1 of 4 1234>
AndrewS
How can you tell?
When you turn the engine off do you hear two or three metallic clunks just as the engine stops rotating? If so your clutch is on the way out Thumbs Up
Post #16810 17th Oct 2009 8:06pm
rangra
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Java Black
Is this on a puma or TD5 engine? LAND ROVER DEFENDER 110 XS SW 2.4
Post #16812 17th Oct 2009 8:40pm
fekete
It will be on the puma Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16817 17th Oct 2009 9:13pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
You seem to know more than the stealers!
Post #16818 17th Oct 2009 9:14pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Generally means the middle is on its way out and may fall out fairly soon!!!
Post #16822 17th Oct 2009 9:43pm
110SEB
Ours makes a light noise some times when the engine is turned off in neutral (I don't leave it in gear). It doesn't sound sinister to me.
Will keep an eye on it and approach dealer before end of the warranty for a fresh clutch if need be.
The only smoother gearbox i've ever felt was on a LR Experience 110 at Eastnor and the instructor attributed this to it having done almost 80% of it's 40,000 miles off road in tough conditions in low box.
Post #16842 18th Oct 2009 9:20am
Eduardo
Humm,
This is the same sound that we discuss time ago, located in the engine (like a pump that are working in dry) or is it other?
Our makes this noise (3 almost non audible clanks) from new and also after a new clutch assembly.
Can you explain more AndrewS, from were is comming and how loudy is?
PD
Looks like a joke or not?
All Pumas do this noise when you turn off or I'm wrong? Eduardo
Post #16851 18th Oct 2009 4:40pm
dgardel
Italy
On your new one Defender??? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #16854 18th Oct 2009 7:31pm
110SEB
The noise is very light indeed, in fact quite soft too. I don't remember not hearing it and we had anew clutch after 6 weeks of owning and that is 3 years ago in May.
Post #16860 18th Oct 2009 10:02pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i ask'd about this noise and was told it was "the waste gate" if i remember rightly and it happens every time you turn of the engine to keep it clear, i was told, just wish i could remember with sertanty.
Post #16865 18th Oct 2009 11:24pm
AndrewS
The EGR makes a noise when the engine stops this is an under bonnet noise.
The nackered clutch noise can be heard coming from the underside of the car. Get out the car, turn off the engine, just as the engine stops you will hear a couple of metallic clunks. The next stage is constant metallic clunking at tick over. This noise can be exaggerated when the AC is turned on. The AC loads the engine drops the tickover speed a little and the noise increases.
Post #16873 19th Oct 2009 11:35am
Eduardo
Thanks AndrewS I will take a look Thumbs Up Eduardo
Post #16876 19th Oct 2009 1:00pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I get 5 (always 5) thack, thack, thack, thack, thack, noises from around the back of the engine every time I turn it off I've been told this may be the wastegate.
Already had the clutch done and the noise Andrew described was also present in the clutch when you started the car without the peddle in. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #16878 19th Oct 2009 1:32pm
Ohlins
France
Defender man here at heart....
For information purposes...what I would say,with my Disco 1 I have had the same sound for about 8 months now....to confirm it was the clutch I put the power hose lance in through the wading plug hole to give it a good soapy wash out...straight away upon stopping the engine,the noise disappeared......a few days later the noise returned. So,next month,I will order up a new clutch. By the by,when I let the clutch out there's always a couple of clicking sounds too which is not the CV joint.
There is 302,000kms on my engine at present,all on its original clutch,so it's about time it was wearing out!! Very Happy
Post #16944 20th Oct 2009 3:05pm
AndrewS
Got the 110 back with the new clutch. Drives great now Thumbs Up feels like a new car and its lovely and quiet
Post #17177 25th Oct 2009 8:54am
Page 1 of 4 1234>
