Home > In Car Electronics > 2.2 90 Base spec headunit install
Page 2 of 2 <12
Just having a look now. Not found anything so far though. Confused WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #221833 24th Mar 2013 10:54pm
Plodster
2011 Defender 110 Puma 2.4 HT Baltic Blue
Censored , glad its not just me! Hmmmmmmm Hmmmm, thats not mud....
Current:
Defender 110 HD Utility (Special Vehicles)
Freelander 2 HSE
BMW E23 735i
Ex:
2013 Defender 90 2.2
1998 Discovery 300TDi
1972 Series II 2.25
1980 Series III 2.25
Post #221843 24th Mar 2013 11:24pm
Seen plenty of options all with part numbers starting with CT20LR with various plug fittings i.e. CT20LR02 CT20LR03.
The plug on yours looks most like the new Discovery / Freelander versions to me. I'd recommend you take out that red protector part (carefully) [It's there to prevent any short circuits so if it's easy to get out for the time being put it back also]
Once it's off take a photo of the connector and it's pins and also take note of the wire colours. From then on post some photo's up here again and I can have a look again. As your Defender is so new an adaptor may not have been released yet so it maybe that if the design and fit is the same and crucially the wires and pins the same that the Disco version may fit. But it's one of those things where you'd have to judge it as being the identical connector on the adaptor to the harness. If even after all that you go to fit and it still doesn't fit you haven't wasted your money. Just cut off the plug on the adaptor that is not ISO and likewise on the LR plug and solder the two together (I'm sure you know how anyway)
Then you will have just one plug and that will be an ISO plug which fits ALL aftermarket HU's.
Sorry I can't help any more at this time I have spent half an hour having a look round. As I said before take that red part off first. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #221847 24th Mar 2013 11:34pm
Here is a start and I'd recommend them as a seller: http://www.caraudiodirect.co.uk/install-adaptors-land-rover/
Various options there but it's obvious the adaptors put down for "Defender" won't fit at all. Silly LR must have been recently busy changing from ISO to Manufactuer / model specific. Not sensible IMO. Rolling Eyes WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #221849 24th Mar 2013 11:36pm
Plodster
Ah that's brilliant, the D4 one looks spot on. I'll see how easy I can source one and see if it's a compatible wiring layout. It's a very backward step going to a manufacturer specific design after previously converting to a standard like ISO, standardisation is one thing but this seems pretty mental.
Anyway, I'll source a D4 adapter and see what's what. Thanks for all your help, I'll update when I have it sorted. Hmmmm, thats not mud....
Current:
Freelander 2 HSE
BMW E23 735i
Ex:
1972 Series II 2.25
Post #221855 24th Mar 2013 11:54pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Online car audio sell them . Connects2 CT20LR04 Wiring Harness for Land Rover
Post #221858 25th Mar 2013 12:19am
This one I assume then is worth a try: http://www.caraudiodirect.co.uk/con-ct20lr...-2010.html I must admit it looks similar. I too agree it is a backwards step going from ISO plugs. Td5's and earlier were manufacturer specific and the 2007 Puma 2.4 went to ISO plugs which IMO was brilliant and a great improvement. All I can think of is LR want to keep the Defender audio market to the selves I.e. so it's not easy to just change to an aftermarket unit if the LR unit breaks down. So owners will go direct to LR for a new HU and because aftermarket won't fit and of course they charge and you get the picture. I'll probably get shot down in flames for saying this too but I think moving to using Alpine equipment as OE for new Defenders is a bad choice indeed. If they must why not offer a range of brands even a couple would do. But Alpine No Thank-You from me... Kenwood, Pioneer & Clarion are some of THE best choices IMO. But each to their own. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #221861 25th Mar 2013 12:38am
Cakey
Must confess no fan of alpine, but the head unit in mine with bt is quite acceptable.
Post #221874 25th Mar 2013 9:34am
Plodster
Interestingly I've checked with local LR dealer's auto electrician and audio fitting chap and another local specialist who have both said that the Ford Fiesta 2008 ISO adapter cable is the one used and much easier to source. The Volvo V70 (1998) version also fits but the speaker pins are reversed.
Apparently the Fiesta one is a straight fit...... Hmmmm, thats not mud....
Current:
Freelander 2 HSE
BMW E23 735i
Ex:
1972 Series II 2.25
Post #222135 25th Mar 2013 9:00pm
If it fits the New Defenders as well then why don't retailers on-line list the fact. Thud Either way looks like your more or less sorted now then. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #222140 25th Mar 2013 9:05pm
Plodster
I sure do hope so! But it ain't over until it's all done and fitted so picking up adapter tomorrow and will test....... Hmmmm, thats not mud....
Current:
Freelander 2 HSE
BMW E23 735i
Ex:
1972 Series II 2.25
Post #222142 25th Mar 2013 9:07pm
Good luck. Thumbs Up It's always best to avoid hacking into wiring looms where ever possible. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #222145 25th Mar 2013 9:14pm
Plodster
Aha! Sorted now, turns out it is a Fiesta 2008> ISO connector but the 12V pin is incorrectly placed so a bridge is necessary in order to deliver power. Very straightforward, remove Purple/Black from LR plug, remove Red from adapter cable and join the two. Hmmmm, thats not mud....
Current:
Freelander 2 HSE
BMW E23 735i
Ex:
1972 Series II 2.25
Post #222559 27th Mar 2013 12:57pm
Excellent news! Mr. Green And all that effort because LR decided to move away from ISO. Rolling Eyes WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #222570 27th Mar 2013 1:45pm
Page 2 of 2 <12
