Home > Technical > feeling a little embarassed.....
Page 2 of 2 <12
Caterham
good idea (again) - thanks Bob.
Post #221457 23rd Mar 2013 6:40pm
Caterham
if I change the batteries will I need to do the key learn ?
or is it just a maybe?
Post #221459 23rd Mar 2013 6:45pm
bob neville
You will, it is all detailed in the handbook and very easy to do Thumbs Up
2013 Defender 90 CSW - sold
Post #221461 23rd Mar 2013 6:53pm
Caterham
Shocked
I must take back what I said ....it would appear the battery did get changed.
indicators flashing so......
starter motor internals Crying or Very sad
Post #221462 23rd Mar 2013 6:56pm
bob neville
Just because the indicators are flashing it does not mean the battery has been changed, it could be low and causing problems with the immobilser.
I would be very surprised if your starter motor is falling to bits, I think you may have more symptoms than just one failure to start Shocked
Change the battery and eliminate that as a cause Thumbs Up
Post #221463 23rd Mar 2013 7:03pm
Caterham
checked the batteries and they are different and I'm sure they'd have been the safe from the factory.
I reckon all is good and I'll just keep a check on things (can't really understand why it would start but I'm hoping it was just a blip - excuse the pun)
here's to wishful thinking
Post #221467 23rd Mar 2013 7:09pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Battery change in the remote fobs is part of the " B " service, ie: every 2 years.
Of course you have to remind the Dealer and supply the 2 fobs. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #221472 23rd Mar 2013 7:38pm
Photoguy1510
New Zealand 2013 Defender 110 Puma 2.2 SW Orkney Grey
Did you relieve yourself against the back tire last time in the bush? LR are characters and they say payback is a bitch just throwing it out there if the shoe fits wear it. 2013 Orkney Grey 110 SE on order should be here on 20/04
Post #228709 18th Apr 2013 8:48pm
Page 2 of 2 <12
