![]() | Home > Technical > feeling a little embarassed..... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
good idea (again) - thanks Bob.
if I change the batteries will I need to do the key learn ?
or is it just a maybe? |
You will, it is all detailed in the handbook and very easy to do
![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
![]() I must take back what I said ....it would appear the battery did get changed. indicators flashing so...... starter motor internals ![]() |
Just because the indicators are flashing it does not mean the battery has been changed, it could be low and causing problems with the immobilser.
I would be very surprised if your starter motor is falling to bits, I think you may have more symptoms than just one failure to start ![]() Change the battery and eliminate that as a cause ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
checked the batteries and they are different and I'm sure they'd have been the safe from the factory.
I reckon all is good and I'll just keep a check on things (can't really understand why it would start but I'm hoping it was just a blip - excuse the pun) here's to wishful thinking |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Battery change in the remote fobs is part of the " B " service, ie: every 2 years.
Of course you have to remind the Dealer and supply the 2 fobs. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Photoguy1510 Member Since: 02 Apr 2013 Location: Wellington Posts: 25 ![]() ![]() ![]() |
Did you relieve yourself against the back tire last time in the bush? LR are characters and they say payback is a bitch just throwing it out there if the shoe fits wear it. 2013 Orkney Grey 110 SE on order should be here on 20/04 |
