Home > Puma (Tdci) > ECU extention ?
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
ECU extention ?
I've been having issues with water in my ecu, land rover told me that it was water proof until i got water in it then they said it was seal'd Mad , i mean who would put the ecu there Evil or Very Mad , well its my fault that water is getting in there they say, so once the warrenty runs out i'm going to move it, now i know that the td5 has had this done by pleanty of people but i can't find one for the puma, any help with this would be much appreciated.
Post #16571 11th Oct 2009 11:13am
alantd
I don't know of anyone that's moved the Puma ECU. It should be straightforward (although you have to get the loom through the bulkhead).
I think you may be blazing a trail there! One that started out as a 2.4 TDCi 110 XS
Post #16576 11th Oct 2009 2:25pm
Rob A
Brazil 2008 Defender 130 Puma 2.4 HCPU Alpine White
I have also been looking into this, but as of yet no luck Sad
Just out of interest, has anyone else had any problems with water getting into the ECU?
Rob 130 HCPU 2.4TDCi
110 300TDi
Post #16584 11th Oct 2009 5:51pm
alantd
If you do go custom, these guys might be able to help http://www.autosparks.co.uk/. Recently used them to knock up a loom for an old Elan.
They do some work for Td5 customers but I don't think they've tackled the Puma yet. I was chatting to them about it at Billing and they were anticipating people wanting to do this at some point. One that started out as a 2.4 TDCi 110 XS
Post #16591 11th Oct 2009 7:45pm
double cab happy
thanks alantd i will.
Post #16601 12th Oct 2009 6:01am
mse
How does the ECU at the back of the engine fair? Mike
Post #16791 17th Oct 2009 1:06am
double cab happy
ask land rover and they will say its water proof, then when it fills up they will say its seald and you must of gone over the wadeing limit, never mind that the ECU will get a good soaking when your jet washing the front of the car wash your bonnet/wing top and the engine gets soak'd, not a problem you would think for a defender?
Post #16848 18th Oct 2009 10:59am
