Home > Wheels & Tyres > Spare Wheel Security.
Page 2 of 3 <123>
K9F
Job done!
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #270101 29th Sep 2013 10:48am
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
very posh Thumbs Up looks good Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #270107 29th Sep 2013 11:51am
K9F
Thank you. I'm pleased with the end result. Just 'donated' my old version to a fellow forum member not too far away who also has a swing away carrier. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #270116 29th Sep 2013 12:39pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I've seen Mal's handywork first hand and it looks the dog's danglies. Great job and very unique Thumbs Up
Mind you, the mkI version is pretty cool too and soon to be fitted to my 90. Thanks for your generosity Mal, much appreciated Cool 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #270305 29th Sep 2013 9:22pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
I personally don't like spare wheels hanging on the back of landy's or on the bonnet I prefure to keep it fixed in the back.
if they are on the outside of the car even if they are not stolen they can be vandalized quite easily and you will only know it when you need to use the spare and find out some scumbag has slashed it / removed the valve / or what ever Wink Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #270426 30th Sep 2013 3:10pm
K9F
Russ you're welcome, hope it fits ok. Thumbs Up
Unfortunately I can't afford to lose the space of storing my wheel in the rear. I haven't seen any threads pertaining spare wheel vandalism, only theft. In mitigation my spare is not covered so I would notice vandalism before I came to use it. You can realistically only react to what is practical, if I had a 110 or the room in the rear I would possibly spend time considering your option. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #270436 30th Sep 2013 3:36pm
cornish rattler
Are right I see, i have had a tyre slashed on the back of one of my series 3 once and ever since I have them in the back and will do with the next landy I get Smile Graham
Post #270481 30th Sep 2013 6:41pm
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Any ideas or recommendations on what type, length of chain/lock to use with a mantec wheel carrier? Boost alloy wheels
Post #270492 30th Sep 2013 7:00pm
K9F
With a Mantec your wheel is attached to three bolts on a plate so you can't pick up on the two unused holes on the wheel as they are blind. You could perhaps consider drilling a hole through the centre of the plate and using the same principle as above instead of using two welded M12 bolts use a centrally welded bolt or bar to pass through the plate and lock off behind perhaps?
If you didn't wish to use an engineering fabrication method just measure the length of chain required using a piece of string or wire passing it through the u bend on the left hand side of the carrier. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #270530 30th Sep 2013 8:07pm
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
K9F wrote:
Another spare stolen recently.
http://www.defender2.net/forum/post267691.html#267691
I decided to 'revisit' my security plate. I also have a brass badge I didn't want to drill the bodywork for.
Laser plate cut from 3mm stainless steel and two M12 bolts welded in situ.....
Front of plate....
Back from powdercoaters....
Badges rivetted and Sikaflexed on.....
Little more 'fettling required and I'll remove the old and fit the new. Which should if my calculations are correct fit directly over the centre of my spare wheel.....hopefully.
Found this thread very interesting and useful but sadly all the pictures are missing. Is there any chance you may still have these pictures? Would you mind posting them again? Thanks Smile
Post #458409 27th Sep 2015 1:37pm
K9F
Amended with what pictures I still have. Hope they help. Whilst not foolproof (nothing ever is) even with the right tooling it would take 15-20 minutes to remove the spare so perhaps put off opportune thieves. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #458493 27th Sep 2015 6:52pm
Edzi
That's great! Thank you so much for uploading the pictures. Very much appreciated. Plus, it looks superb; a job nicely done!
Post #458531 27th Sep 2015 8:15pm
RRUK
I've bought myself one of these to keep mine on the car, along with 3 locking wheel nuts.
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #458537 27th Sep 2015 8:34pm
Edzi
That was the first solution I saw and rathe liked. Just read that padlock doesn't fair well in the rain over time though. Might be worth seeing if you can get a similar sized padlock which is fully waterproofed / water resistant?
I was thinking if I do get one, I'd get some sort of metal shield built to go above and around it to shelter the lock as much as possible from the elements.
Post #458572 27th Sep 2015 10:51pm
X4SKP
Hello All,
I remembered K9F / Mal's post, and liked the idea of not just relying on a Security Lock Nut(s) when it comes to protecting the Spare Wheel.
My route is a variation along the same lines, Mantec Spare Wheel Carrier + Alloy Adapter (for the Wheels fitted), then my 'Cover Plate' behind the Adapter, a 'Through Post' to set up the 'Wheel Nut Cover Cone' and Quality Lock.
Materials a combination of Stainless Steel, Molybdenum Steel, Marine Grade Aluminium Alloy, Nylon and Neoprene.
 SKIP
Post #458612 28th Sep 2015 9:09am
Page 2 of 3 <123>
