Home > Td5 > Clutch pedal creak...
Gareth
Ever since I did the clutch pedal mod with the later type spring, I have suffered a very annoying creak every time the clutch was let out. No amount of oil or Wd sprayed at the spring seemed to cure it.
Today I had a couple of minutes and took the 6 screws that hold the pedal box cover off. Then used some spray grease on the pedal pivot and adjuster, and hey presto - no more creak!
Simple things..... 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #217427 9th Mar 2013 1:25pm
Green Machine
Mine does it too, so I will have to do the same! Thanks for the tip. I know that I also need to replace the rubber gasket on the pedal box cover, so will do that at the same time. The last time I took it off, it pretty much disintegrated. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #217456 9th Mar 2013 3:38pm
Defender-Stu
Had this on mine sort of, during the snow period and my mate next door who works for the aa sorted it out for me on the tdci Thumbs Up
Post #217464 9th Mar 2013 4:05pm
