Home > Maintenance & Modifications > air filter and exhaust
Page 3 of 3 <123
geobloke
ZeDefender wrote:
Many thanks - I wonder what the maximum value is? Were all your readings from the same garage/machine?
If the max value is e.g. 5 K(1/m) then that variability doesn't matter...
Matt
Morning Matt.
Over here the emissions test works something like this; If the engine achieves 1.5 K(1/m) or below on its first rev then it passes the emissions test, if it fails then an average of 3 readings is taken. If the average reading is at or below 3 K(1/m) then it is a pass, if not the test is re-done for another average of 3 readings and if it fails that then it fails... They really give the vehicle every chance.
http://www.dvtani.gov.uk/uploads/customers...eaflet.pdf
An MOT guy I spoke to says that it is really important to give the vehicle a darned good run before getting it tested as it could 1/2 the amount of particulates. He also said it was worthwhile servicing the vehicle and flushing it with something like 10k diesel or Wurth as that also helps.
The TD5 MOTs were done a 2 stations and the 200tdi at another.
Going on that info, the td5 even with 6k miles on the oil and filters managed to get through the first test...
Post #216315 5th Mar 2013 11:01am
ZeDefender
Shocked Thumbs Up Brilliant info Bow down
Many thanks - I'm getting a bit more optimistic again Smile Tell someone you love them today because life is short.
Post #216351 5th Mar 2013 1:02pm
geobloke
You're welcome. Now go out and start flashing that cash, your poor ol' Fender is feeling unloved and under powered... Wink
Post #216353 5th Mar 2013 1:10pm
Page 3 of 3 <123
