![]() | Home > Wheels & Tyres > Spare wheel removel |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
I guess it depends how pedantic you are about aesthtics!
The bolts would probably do the job of plugging the holes, whilst not looking dreadful. Going the whole way, would look better but would cost a lot more time and money, and also isn't as easily reversible. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20715 ![]() ![]() |
How about some SS bolts painted black but with a domed head so it doesn't as such look like a fixing. Or indeed perhaps even better body painted colour.
Bolts like this: ![]() Click image to enlarge As you can see they are blank and dome headed so no visible fixing as such and if body coloured hardly noticeable. Not expensive either. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
I done this last weekend on my 90, after removing the spare wheel carrier you can see the door is all blemishy were the bolts have been nipped up
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Ric Member Since: 04 Nov 2012 Location: South Yorkshire Posts: 209 ![]() ![]() ![]() |
Custom Steve. Thanks, have you a link, and how would you tighten them
![]() killer, any pics its only a car! |
To tighten you'd have to either tighten just enough to be secure or from the inside cut a small slot in the end of the bolt to a small screwdriver to hold the bolt in place. Alternatively you could go for and Allen head bolt instead if you'd prefer not having this effort but you will have the fixing head visible. Some ideas here:
http://www.ebay.co.uk/sch/i.html?_nkw=dome...;_from=R40 Allen head though but on hindsight probably your best option. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Still not got around to this, its a job for the week,
what size bolts are they? any tips for the removal of the plastic trim on the inside of the door? its only a car! |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Trim comes off easy - just unbolt the grab handle and there's a little plate behind the internal door catch handle that unclips. Then the plastic door card just comes off, it's clipped around the edge with plastic clips. Make sure you pull it 'square' otherwise the clips can break. Trim removal tool can be handy, if you have one. Alternatively, two small flat blade screwdrivers either side of the fixings with equal pressure applied to each. 2005 Td5 | 90 Station Wagon | Tonga Green
Thanks GM
Are they M8's that hold the bracket on? its only a car! |
M8 x 50 flanged bolts according to MicroCat
That's a hard way of doing things.....Just buy the domeheads and run a normal low proifile nut down the thread, nip them up whilst holding the end of the threaded portion (or use a further two nuts to lock off the third) and then run a nylock over the top. Job's a goodun and Bob would be your Auntie if he had his bits lobbed off. ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
