Home > Wheels & Tyres > Spare wheel removel
Ric
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Spare wheel removel
If I was to take the spare wheel bracket off, would you suggest plugging the holes, leaving the bolts in or filling and re-painting
Just a thought its only a car!
Post #214753 27th Feb 2013 5:14pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I guess it depends how pedantic you are about aesthtics!
The bolts would probably do the job of plugging the holes, whilst not looking dreadful.
Going the whole way, would look better but would cost a lot more time and money, and also isn't as easily reversible.
Post #214763 27th Feb 2013 5:33pm
How about some SS bolts painted black but with a domed head so it doesn't as such look like a fixing. Or indeed perhaps even better body painted colour.
Bolts like this:
As you can see they are blank and dome headed so no visible fixing as such and if body coloured hardly noticeable. Not expensive either. TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #214768 27th Feb 2013 5:43pm
Killer90
Site Sponsor
I done this last weekend on my 90, after removing the spare wheel carrier you can see the door is all blemishy were the bolts have been nipped up Big Cry so decided to put it back on Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #214823 27th Feb 2013 8:23pm
Ric
Custom Steve. Thanks, have you a link, and how would you tighten them Rolling Eyes
killer, any pics its only a car!
Post #214912 28th Feb 2013 12:08am
To tighten you'd have to either tighten just enough to be secure or from the inside cut a small slot in the end of the bolt to a small screwdriver to hold the bolt in place. Alternatively you could go for and Allen head bolt instead if you'd prefer not having this effort but you will have the fixing head visible. Some ideas here:
http://www.ebay.co.uk/sch/i.html?_nkw=dome...;_from=R40
Allen head though but on hindsight probably your best option. TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #214996 28th Feb 2013 12:35pm
Ric
Still not got around to this, its a job for the week,
what size bolts are they?
any tips for the removal of the plastic trim on the inside of the door? its only a car!
Post #236870 19th May 2013 4:52pm
Green Machine
Trim comes off easy - just unbolt the grab handle and there's a little plate behind the internal door catch handle that unclips. Then the plastic door card just comes off, it's clipped around the edge with plastic clips. Make sure you pull it 'square' otherwise the clips can break. Trim removal tool can be handy, if you have one. Alternatively, two small flat blade screwdrivers either side of the fixings with equal pressure applied to each. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #236881 19th May 2013 5:48pm
Ric
Thanks GM
Are they M8's that hold the bracket on? its only a car!
Post #237050 19th May 2013 11:03pm
Green Machine
M8 x 50 flanged bolts according to MicroCat Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #237079 20th May 2013 7:34am
K9F
custom90steve wrote:
To tighten you'd have to either tighten just enough to be secure or from the inside cut a small slot in the end of the bolt to a small screwdriver to hold the bolt in place. .
That's a hard way of doing things.....Just buy the domeheads and run a normal low proifile nut down the thread, nip them up whilst holding the end of the threaded portion (or use a further two nuts to lock off the third) and then run a nylock over the top.
Job's a goodun and Bob would be your Auntie if he had his bits lobbed off. Thumbs Up Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #237211 20th May 2013 5:32pm
