Home > Maintenance & Modifications > JE engineering 2.2 tune
Page 1 of 3 123>
Jez676
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I was speaking to JE Engineering today about another subject and they told me that they will be bringing out a new remap for the 2.2 Puma within the next 2 weeks. There will be stage one which is the remap on its own and stage two which is remap, intercooler and cold air intake. According to them it's all tested dynoed and ready to go Razz
Post #214670 27th Feb 2013 12:16am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
interesting ? lets see how long 2 weeks takes Whistle
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #214730 27th Feb 2013 2:10pm
barbel jim
From my recent experience with them 3 months and still waiting. Not puma related, but a local customer who's family have dealt with them for over 25years. and yes i have prompted them a couple of times Whistle Whistle
sorry to be negative Sad
Post #214743 27th Feb 2013 4:16pm
rover
JE Engineering are advertising a 2.2 defender remap, 165bhp stage 1, 180bhp stage 2. Its in one of the land rover mags this month. Land Rover World or Monthly not sure which.
Post #218119 11th Mar 2013 8:41pm
big steve
same as what they quote for a 2.4 then ?
Post #218124 11th Mar 2013 8:53pm
bell-auto-services
They must have put it in early to get it to print on time as they have told me today
Quote:
they managed some gains needs more work and has not been on the dyno yet but they are hoping next week
Pete
Post #218131 11th Mar 2013 9:05pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
That'll be the last time they tell you anything!
Post #218143 11th Mar 2013 9:36pm
bell-auto-services
lol true, I do think this time in their defence its about them having the need to get adds in early with the magasines to be honest, LRO especially are a nightmare as they want words and pictures nearly 3 months before the mag comes out. sometimes prospection adds are the only way to be on time with the real world progression and developement.
Pete
Post #218150 11th Mar 2013 9:40pm
keith
The whole point of the 2.2 remap isn't to get more power , mpg or torque but to get the engine working the way it should do . So does this remap include removal of the DPF ? And a fix for the holding revs issue ? My whole drive train , gearbox and clutch has been affected by the crazy set up , roll on the remap and DPF fix .
Post #218209 11th Mar 2013 11:35pm
RobKeay
Sounds like you may have a deeper problem than just a remap!
Post #218211 11th Mar 2013 11:40pm
keith
Shocking gear changes , holding revs for 2-3 secs , clunk , clunk , clunk on reversing ( front prop I think as loadsa play on it ) and other related issues . Dealer says normal and can't fault it ? This engine has been strangled within an inch of its life to tick the boxes of the Eu emitions and I recon the only fix is the correct remap to put it back to normal .
Post #218214 12th Mar 2013 12:03am
bell-auto-services
The DPF its self is easy eniough to electroniclly remove from the ecu as well as the related dtc's attached to it after its removal, the hardest part is the removal of the DPF its self mechaniclly from the car which is very labor intencive as seen in this pdf.
https://www.defender2.net/gallery/albums/u...move~0.pdf
The holding revs which is partly to do with the "Tipin value" can be adjusted if needed of which it has been on some of the later calibrations I assume to mask a little or address the rev holing problem being reported by many. It seems that most of the early calibrations especially on 90's have previousley used a different value in some of the maps which as said causes the revs to hold a lot longer when changing gears which is exaggerated especially on cars that have have large or wide wheels fitted.
Pete
Post #218215 12th Mar 2013 12:12am
keith
WAW ! Amazing diagrams and description thanks . I'm sure I have given yourself all my issues before and one of my questions was if you would do the removal at the same time as the new remap ? As it would be required to get the car running again . Keith
Post #218217 12th Mar 2013 12:21am
RobKeay
Mine tends to kangaroo sometimes. So I to am thinking about a map but am nervous about doing it on a new one.
Post #218224 12th Mar 2013 12:59am
bell-auto-services
At the moment I'm keeping the DPF removal for development for a ltiile longer until further testing is done, Regarding removal, the contents of the original pipe can be removed from the insides then it can replaced or I'm working on a new front pipe also between other jobs for a full replacement.
Of course this serious and in most cases visible modification will for sure have dealer warranty implications.
Pete
Post #218235 12th Mar 2013 8:15am
Page 1 of 3 123>
