![]() | Home > Maintenance & Modifications > Fitting a tracker |
Turned out nice again (George Formby grin) ![]() But shout it at them in German because life is also terrifying and confusing... |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
For those that were testing the app, it's passed review and is available on the app store now...
https://itunes.apple.com/gb/app/tkcontroll...1&mt=8 You should delete the test app and install the release one from the app store. http://www.yorkshireoffroadclub.net/ |
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
Dave, App looks great! Do you think its possible to adapt the app with the commands for my tracker? Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
I think so, although it's not as straight forward as just changing the commands, for the stockade function, as an example, you have to set the stockade first and then activate it as a separate command as far as I can see from the manual anyway.
I'm looking at adding a "device type" to the device settings which will allow me to change the way the app behaves and the text on the various buttons. With that in mind and assuming it stays with 8 buttons on the front screen, what would be your preferred functions for each of the buttons ? Stockade On/Off can presumably stay the same with perhaps an extra button on the stockade map screen to set the stockade area ? http://www.yorkshireoffroadclub.net/ |
My device does not have a Shock sensor, so the Shock On / Shock Off button could have an other function, e.a. 2 preset stockage area's? Or you could switch the relay on and off with these buttons?
I did buy this device with a group buy together with about 60 other members of a Land Rover forum here in the Netherlands, so I think there would be more people interested in this app ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Sorry Dave, I was not one of the testers but I've just downloaded the app and it's brill ![]() Would you have any objections if I promoted the app elsewhere ? ![]() |
+1
![]() Found my replacement delivered in the garage and tested with the app already - brill ![]() Only thing that would make it significantly better would be if the phoning/messaging was all internal to the app itself, rather than having to open the native phone/message apps but I realise that will never be possible due to the nature of the tracker's function. It's a great piece of work and makes controlling the tracker sooo much easier (and posher too) ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Not at all, promote away ![]() |
Hi Dave
For some reason, my TK102 (latest V6) responds to "shake" as a command, not "shock". Is there any way for me to change it? Also, Get Status ("check") has no effect on my tracker (no sign of it in the handbook either) - is this a function of the other units? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Might be because you have a TK102 rather than a TK102-2 mine are TK102-2 and I assumed they'd all be the same, command wise...
Changing the command is no big deal, did your unit come with a CD with a copy of the manual on it by any chance ? http://www.yorkshireoffroadclub.net/ |
Apparently "TK102 V6" is just GPSVision's name for the Xexun TK102-2 (V6 is one of the newest models).
Mine has the shake sensor and microSD (don't think the older TK102's have one). Perhaps shake/shock is a firmware difference? Also, my command is "shakeXXXXXX 1" where "1" is the sensitivity (can be between 1 and 10... 0 turns it off). The app's "Shock" command doesnt have this? Came with a manual but no CD. GPSVision is one of the main distributors for Xexun in Germany and they print their own manuals in German. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 27th Feb 2013 7:15pm. Edited 1 time in total |
This list uses "shake":
http://forum.gps-trace.com/viewtopic.php?id=3689 Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Really handy looking app DaveW
![]() Any chance it can be made to work with a 3gs running iOS 4.3? I know I could upgrade to a higher iOS version, but this would compromise a couple of my other handy 'apps" ![]() Also I see that it can work on an ipad but I can't send commands via text from my ipad? (or have a got something wrong somewhere?) The tracker that it works with is the one available from "Bondstory" , if so I'll get some on order as I have a couple of things I want to keep an eye on. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
