Home > Puma (Tdci) > Puma 110 Fuel Tank Capacity ??? |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
68L ????
14th Sep 2009 7:51pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Wrong California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
14th Sep 2009 7:54pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Hmmmmm,
Tank capacity is 75l, so how about 72litres? Glyn |
14th Sep 2009 8:02pm |
Well my handbook says 73 lts,, the LR website says 75lts Both wrong California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
14th Sep 2009 8:04pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
I'm the kind of guy who'll drive on vapours (even though it's a bad idea in diesels) - i reckon with it filled up through the pipe to the brim 77 litres?
14th Sep 2009 8:26pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Most I've ever got in mine is 68L (obviously some in the tank) One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
14th Sep 2009 8:45pm |
Close enough i recon ,,, 76.6 lts must have been on fumes
What to guess the miles covered ?? Towing a BJ race shuttle, total weight 2350kg,, half load in the rear with a dozen wheel/tyres on the rack , motorway all the way to Dover, then 86 miles M/way.a-roads Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Bluewagon Member Since: 06 May 2009 Location: North Brighton South Australia Posts: 5 |
I used to have a petrol County 110 with a sill tank and a manual switch that I drained dry each time before switching to the main. I could never fit more than 56 litres in until I found a partuicular fuel station with "cheap " discount fuel. Managed to get 58 ltres in both times I went there. After that I didn't go back because I had a strong suspicion that their pump was inaccurate(most likely deliberately). It also made me wonder how common fiddling with the pump measuring system was in fuel stations. Seems an easy way to make money with very little chance of getting caught. Any chance your fuel station had a dodgy pump? |
15th Sep 2009 4:37am |
Very much doubt it,, was a largish station, and they are pretty tight on weights and measures etc in this part of the world,, but you never know,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
15th Sep 2009 7:27am |
Very unlikely. Fuel stations are heavily regulated here. I read something recently about this and the fuel flow rates are calibrated to some extraordinary level or accuracy - way more than we would ever care about. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
15th Sep 2009 7:35am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
15th Sep 2009 12:57pm |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
The tank capacity itself may be 75l but that doesn't include the filler neck and any fuel that's already in the system which may be a couple of extra litres. The odd thing is, shouldn't the vehicle have gone into limp mode when it was down to 5l? I think that's what the manual says should happen. There's a whole section explaining how the engine shuts down when fuel is very low to prevent damage from running dry. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
15th Sep 2009 11:30pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Some days ago we filled the tank with 65 liters just few minutes after the fuel alarm start.
I thought that the diesel thermal expansion coeficient can explain certain differences between the measures but really as I see in the literature 0.00046/°F that is not quite much and can explain a little bit more than 1 lt of difference between 5°C to 30°C. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
16th Sep 2009 2:37pm |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
Click image to enlarge In Greece we have bigger tanks www.newfoundland.gr |
15th Jul 2021 4:13pm |
