Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Watching with interest ( as ever )
Did you go for the Britpart kit? |
20th Mar 2015 5:52pm |
Managed to get a couple of bits painted up so when the weather is a bit warmer and nicer I can get them fitted and it should look tidier
Sorry for the rubbish pic. Click image to enlarge Ray |
23rd Mar 2015 6:28pm |
All the bits for a big job finally collected so should be going on in a couple of weeks started with the crank pully starting to go but ended up deciding to do everything while the front was off so it's getting pully, new pully bolt, aux belt, crank seal, both idlers, tensioner, water pump, power steering pump, radiator, intercooler and the silicone hoses that have finally turned up correct after 6 weeks also in the pics to do are the rear anti roll bar, new sills and the rest of the stainless bolt kit! So a busy time ahead but hopefully everything should be running great when it's finished :
I'm hoping britpart can't mess up a radiator as everything else is oem. Click image to enlarge Click image to enlarge Thanks for looking Ray |
24th Mar 2015 5:03pm |
New springs have arrived -2.5 rear and -1.5 front by extreme. Another ebay bargain having only been used for around 100 miles before the chap sold his 110 so I got them at 1/4 of the original price I just need some spare time and good weather to put all these bits on
1st Apr 2015 1:29pm |
Started the lowering job and got the backs in already. Just having a rest before tackling the fronts
Old and new Click image to enlarge One in Click image to enlarge And the back done Click image to enlarge Cheers for looking Ray |
4th Apr 2015 12:55pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
doesnt look right mate! take them out send them to me and i will dispose of them for you! My 109 thread
my youtube channel |
4th Apr 2015 12:57pm |
Fair enough, give me half an hour
4th Apr 2015 12:58pm |
on serious note, i wonder if you could still fit 255 85 16s under there now My 109 thread
Not sure, what's the difference in wall hight? I think I'm going for the 18" sawtooths that lri solutions do next year when I've recovered from the expense of all these new bits so I need to check out what tyre sizes are best for a bigger wheel.
Ray |
4th Apr 2015 1:03pm |
255s have 33inch diameter so about an inch more than 265s
i would like to lower mine to make easier access for dogs and swmbo, but put 255s on to lift diffs a little. My 109 thread my youtube channel |
4th Apr 2015 1:31pm |
I've got 235's on mine and it had 4 1/4 inch gap from tyre to arch at the front and 5 1/2 gap at the back and although I've not driven it to settle the springs yet it sits level at 3 1/2 inch gap all round now. My old springs had done 110000 miles though so we're more than likely sagging a fair bit anyway.
Fronts old and new Click image to enlarge And all done, just need to test drive it now Click image to enlarge A bit of adjustment on the garage door and it should fit in Ray |
4th Apr 2015 4:27pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Looking good Ray. What shocks are you using? My back end is up and down like a yo yo and I can't decide between oem oil or after market gas. 2002 110 td5
4th Apr 2015 6:00pm |
To be honest I'm not sure my garage put them on all round a year or so ago as the old ones were shot. I was going to put some bilstein on when I was fitting the springs because they get good reviews but with these being so new and in perfect working order I decided against changing.
Ray |
4th Apr 2015 6:37pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3786 |
Looks good to me.
Will you be getting a front end alignment? Pickles. |
4th Apr 2015 9:50pm |
