![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
So, the new bumper was bolted on when dry and the wing chequer plate and A bar were powder coated and everything was bolted on apart from the spots as I've taken them apart to fit a new lens and a full clean up. She's booked in next week to have the two head lamp panels and drivers door painted then I can get on with some other bits
![]() As she stands at the mo. ![]() Click image to enlarge Ray Last edited by mk1collector on 10th Sep 2017 10:04pm. Edited 1 time in total |
All said and done i did quite well out of the young lad crashing into me as I didn't have to pay for lots of bits I wanted doing anyway
![]() I got two new outer wings New bumper and end caps New front door hinges Wing chequer plate powder coated A bar powder coated Headlamp panels and drivers door painted New spot light lens Few cans of dinitrol All I had to do was bolt everything together which I would have done anyway ![]() |
As I've got no big jobs planned on the house for a while I've taken the roof rack off and gained an extra 5 to 10 miles per tank (depending on driving) which is good
Standard and boring
![]() ![]() Click image to enlarge Last edited by mk1collector on 10th Sep 2017 10:05pm. Edited 1 time in total |
Tubes63 Member Since: 05 Aug 2012 Location: Edinburgh Posts: 201 ![]() ![]() ![]() |
I think it looks best like that, myself
![]() 2007 Defender 90 ![]() Click image to enlarge |
![]() Click image to enlarge So this was the last pic I got before she disappeared to a local garage for a month with a head gasket leak and a starting/running problem ![]() ![]() ![]() So this is her now ![]() Click image to enlarge As you can see the spots are back on, she's had a wash and I've finally figured out the previous owners bodge that was stopping the horn and rear wash working properly. In the next few weeks I'm going to pick up some goodies from Brendan on here so there should be some more progress soon and I've got a few more plans before the end of the year so keep tuned ![]() Ray Last edited by mk1collector on 10th Sep 2017 6:58pm. Edited 1 time in total |
So, I've been a little busy with my 110. First off all the rear seats and trim came out so I could seal up all the built in gaps and leaking points from lr then came the dynamat
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Once the deadening was done a layer of closed cell foam was put over the top and rubber mats were put over the top( including the nakatanenga load mat from Brendan) and all the trim etc was replaced. ![]() Click image to enlarge The under cubby safe (again from Brendan) and relocated handbrake lever was next. ![]() Click image to enlarge I ve also started fitting air con but that will be finished after I come back from holiday (hopefully) and last but not least today I've just received the new clutch spring kit from Simon (mps trading) and fitted it this afternoon so the drive to France should be more pleasant. Still to come are some tinted windows that don't rattle and after the holiday a few mods for winter but ill update on those later. Sorry for the million pics ![]() Cheers Ray Last edited by mk1collector on 10th Sep 2017 7:01pm. Edited 1 time in total |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
![]() ![]() It would be rude not to after all that sound proofing. How do you find the under cubby safe? Is the arm rest now the right height or gone the other way and ended up too high? |
hamtheman Member Since: 19 Mar 2013 Location: Louth Posts: 35 ![]() ![]() ![]() |
Lovely machine! I was only thinking recently - "Man I could do with moving the Hand Brake!" and now look!! Great! http://mylandy90.blogspot.ie/
Ha ha, DVD player will have to wait until I've done all the roof and upper sides with sound deadening and closed cell but I think one is definitely on the cards. As for the cubby safe, it's made the cubby perfect for resting my arm on but now I'm going to have to buy a new cubby as I'd forgotten how tatty it was and I don't think it's an original lr one anyway as its a bit long ![]() |
Thank you, the handbrake move is pretty easy (it only took me a couple hours) and you can use an RRC handbrake but make sure you have the right one, or a disco 1 lever. There's a thread in the maintenance and mod section with a link to reedx with a good write up of the job. I'd link you too it but I don't know how, sorry ![]() Ray |
Well I'm off on my hols soon so figured I'd lose the weight of the tow bar for the trip as it getting blasted and re-powder coated some time after I get back. So today off it came and at the same time I re-bolted the rear step back on securely without the rubbish rivnuts and I also relocated the tow electrics to the hole in the rear cross member. In the past week she's also been in for new swivel housings and bearings, wheel bearings, new front callipers, discs and pads and a full service with diff lock evo 1 oil in the gearbox to make it a bit smoother so hopefully she will be in good health for the drive to France.
Ray |
Enjoy your holiday ray. It sounds like the defender is ready for it. I got back yesterday after 2200 miles without any problems. In fact, it was raining on the last day so we cancelled our last overnight stop and came back from Le Mans all in one. Even fully loaded and the rack and roof tent, she still managed 25 to the gallon at 70 mph!
