Home > Td5 > Switch location
mfspannerman
United Kingdom 2002 Defender 90 Td5 HT Oslo Blue
Switch location
This question has probably been asked loads before but carn't find anything??
I have an 02 defender i am looking to add extra lights so need to add extra switchs i am just trying to work out what switchs people have used and where they have mounted them? Make tracks and get moving!!
PUTTING FOOD ON YOUR PLATE IS WORTH THE WAIT! PLEASE BE PATIENT!
Post #200017 8th Jan 2013 5:53pm
whelo
Wales
Hi, i used a front fog switch, http://britishparts.co.uk/products/6034-sw...000540LNFG
I had it somewhere else alot cheaper, it fits in the centre dash top left, looks like it came out of the factory.
Other option is http://www.mudstuff.co.uk/Td5_Fascia_Plate.shtml I've also fitted this with the 6 carling switches, looks neat enough.
Jason Getting there, slowly..
Post #200800 11th Jan 2013 12:06pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
There is a photo of the location of my spot light switch (came with the TR), great if you dont have any spact on the new style dash...
http://www.defender2.net/forum/topic14780.html
Post #200806 11th Jan 2013 12:27pm
whelo
Wales
This is a better pic of the switch http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1c23ae17f6
But i did find it cheaper somewhere, i'll try & find the receipt weekend.
Post #200807 11th Jan 2013 12:27pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
The front fog switch has increased from £10 to £50 over the last couple of years.
I needed two switches for sopt and fog lights and have installed two Carling switches where the electric window switches go on the Td5 dash - do electric windows on my basic Td5
I used the on-off-on switch so when up they come on with main beam, when switched down they come on independently
They only cost about £9 each
Post #200817 11th Jan 2013 1:27pm
Tiger
http://www.rimmerbros.co.uk/Item--i-YUG000540LNF
Is the best one but it ain't cheap
Post #200828 11th Jan 2013 2:08pm
JWL
When I got my 2002 Td5 it had a few extra holes in the centre console, the police who had it before had been a bit quick off the mark at plonking switches wherever Rolling Eyes They had put switches in on the flat bit at the front below the radio between the cigarette lighter and the headlamp levelling switch. I put an extra lighter socket(12v permanent with the original 12v ignition switched next to it), 2 rectangular blanks from off a Discovery electric window console, went into 2 empty holes which I then cut 2 smaller rocker switches into to control my stewarding lights and an overide on the heated front screen. Another hole is filled with a switch for heated mirrors. Quite busy but fairly tidy. On the front of my cubby box I made a plate to carry a pair of toggle switches to control my battery monitor and my battery charging relay.
With ingenuity you can keep the dash tidy and also functional but I did manage to buy my LR front screen and 2nd front lights switches for a reasonable price last year before they became silly money.
Another place to put switches/controls is on the fuse board panel, my Eberspacher controls are on there.
Post #200829 11th Jan 2013 2:11pm
whelo
Wales
Thought so, i'm too tight to pay that much for a switch. Shocked
Just wish i'd bought some more now. Very Happy
Post #200875 11th Jan 2013 6:08pm
mfspannerman
Thank you all for your replys! I have found this on eBay was wondering if anyone knows it would fit between the fag lighter socket and the head light switch?
Look at this on eBay:
LAND ROVER DEFENDER SWITCH MOUNTING TRIM PANEL
http://bit.ly/VQBuO8 Make tracks and get moving!!
Post #200876 11th Jan 2013 6:08pm
Tiger
Not sure, it's the one from the RHS of a pre 2001 Dash. Used to have Fogs and Hazzards in it. Old Lucas style switches like you used to get in Mini and MGBs
Post #200877 11th Jan 2013 6:11pm
whelo
Wales
You'd b better putting it on the right hand side.
Might fit in the space under the radio? or th switches might, bit fiddly..
Post #200880 11th Jan 2013 6:21pm
mfspannerman
Yeah that what I assume it was for but wondered if it would fit under radio as you can buy that and 3 switches for the same money as a carling switch holder! Just a thought? Make tracks and get moving!!
Post #200887 11th Jan 2013 6:44pm
whelo
Wales
Its probably worth a punt at £4.50.
Post #200921 11th Jan 2013 8:01pm
